Paint & Body Q: Would You Use This Decklid?
I bought a flat decklid to replace my duck (going for the clean original look) and knew the decklid I bought was in rough shape ("has some rust") but otherwise it's a fairly straight lid. So yesterday I (finally) started removing some of the paint to see how bad the rust is and I wanted to get some opinions on whether or not I should continue to use this lid (i.e. clean it up as best I can and give it to somebody to paint) or should I start over with something else. Right now I have less than $100 invested in this lid, so keep in mind buying another lid would cost more and I'd still have to have it painted. But if this lid isn't worth saving, then I'll start over and write this off as yet another lesson learned. Anywho...
This is the main area of concern, where the frame meets with the skin just south of the latch area. ![]() ![]() ![]() The center part of the frame has actually separated from the skin, but the sides / corners still look together (I can't pry them apart with a screwdriver or anything). ![]() ![]() And the outside shows no signs of rusting through. ![]() ![]() ![]() ![]() The rest is supperficial rust, most of which I've ground off already and can get down to clean metal. The car is a driver so I'm not worried about a concours quality part. I just want a flat lid that works and looks decent. So what do we think? Carry on with reckless abandon or junk it now? Thanks.
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
One more pic of the whole lid...
I dont claim to be a body man but past experience suggest to me that the rust will probably come back to haunt you in a year or so..
If its going on a keeper I'd look for another one. Just my opinon. lets see what the others say... |
The car is a keeper, but the lid...maybe not so much?
A related question...I bought some product that supposedly "desolves" rust...is this possible? I was going to try it tonight and see how well it works. (I'm having trouble getting any kind of grinder down into the tight gap on the lid.) Cheers.
cycling has-been
no
it's already had a tail attached, so if flat is your aim, you are going to have to fill, build and sand to achieve a respectable surface, plus, and you're going to have to locate and drill for the period correct letters and emblems, if that's where you're headed. lots of added work ahead there are too many nice ones of these floating around at bargain prices to be spending a lot of time, or money, on this example Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 06-05-2009 at 06:53 AM.. |
have it bead blasted to check integrity and primed immediately if not swiss cheese. ive seen worse
I'd finish stripping it... Then make your decision. Send it out to a professional stripper if you want I'm sure you can get your money out it if you want to move on. Unless you buy a lid that has already been stripped how will you know that the next lid is any better?
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
1.367m later
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
FWIW I'm going to leave the decklid clean...i.e. no labels, numbers, etc. Also, I don't mind the time, it's the money that I'm short of right now. But at some level, time is money, so...
Find a good one on ebay and resell that one. There are several of them out there.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Ruby911
I would be leery of rust that has started under the seam around the edge that you cant get to to clean up will surface at a later date. I replaced an aftermarket glass lid on mine with an original. The inside was completely clean, no evidence of rust at all. After stripping the exterior of the decklid, we found a couple of rust spots that had not yet bubbled the original paint. I would hate for you to put all the work that it sounds like you are going to have to do, just to have the paint bubble in the near future.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Thanks all for the opinions. Just to update, I'm working with another lid. It arrived today and is a nice, straight, rust free piece offered from another Pelican (thanks Bob!). I'll post pics when I have a camera around.
Also, many have said this before, but just in case you missed it...Pelicans rock.
