batteries for a 1970 911t
Hello all,
would you advise any good supplier for getting two new batteries for my 1970 911T? What are the price ranges for these? Thanks a lot regards Boz |
I got a pair from the local dealer.I believe it's an Interstate U 911.They were about $90.00 each
Thanks a lot! Where these for a 70 911T too?
thanks regards Mat |
My car is a 69T but the batteries are the same for both years.
thanks a lot for your advices.
regards Mat |
Best way to save money (and weight) is to only use one battery.
I have use the interstate U911 for years with only one battery. No problems starting, but you must remember to disconnect the second battery cable from the clamp.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
Sonnenschein makes great replacement batteries...do a search and you should find some purchasing info They are an exact replacement size and I believe they are a dry cell battery so the worries of them causing rust are minimized. Have had my set for about 2 years and they have been great.
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Hi, do you mean the interstate u911 is a 12v?
thanks again Mat |
Regis turd ab user
Ditto on the Sonnenschein, the model for '69-'73 is the DF 75.
http://www.batterysales.com/sonnenschein_prevailerger.cfm |
Thanks all for your advices. Would a pair of Interstate u911-50 be the cheapest solution?
Thanks a gain mat |
The cost of a lead acid battery is less until you consider the cost of a front suspension pan replacement from a boiled over or cracked battery.
From another post (http://forums.pelicanparts.com/porsche-911-technical-forum/479604-duel-battries-post4717642.html?highlight=optima#post4717642): Quote:
