Guest
Posts: n/a
How much horsepower do you run?
How much does your horsepower does your 911 run?ANd how much torgue? Also do you know how much HP an 83 targa carerra runs?
Thanks Rafal ------------------ 85.5 Porsche 944 |
Guest
Posts: n/a
Rafal,
My 2.4 makes 190 hp DIN (181 hp SAE net) at 6500 rpm, and 22 m-kg (156 lb-ft SAE) at 5200 rpm. The USA '83 Targa is an SC, and makes 180 hp DIN (172 hp SAE net) at 5500 rpm, and 27 m-kg (189 lb-ft SAE) at 4200 rpm. ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
MY 88 911 carrera,276.1 HP at 5900rpm with 240 Torque.
Regards Juan www.geocities.com/titos88911/MY911.HTML |
Guest
Posts: n/a
Early S Man, Is there any mods that dont cost a lot that I can do to increase the HP from 180 to something higher?
Guest
Posts: n/a
Rafal,
No, I really don't think there are any inexpenive mods to be done, though if your state doesn't require visual or sniffing smog tests, a set of used early '65-'74 heat exchangers and muffler would yield about 20-25 hp. The Porsche 911 Performance Handbook, by Bruce Anderson has the most information available anywhere about the history of 911 engines, rebulds, and modifications that can be done! ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks a lot, oh yeah one last thing...do you know the 0-60 times on it?
Guest
Posts: n/a
For an '83, somewhere in the 6.5 to 7 second vicinity.
Guest
Posts: n/a
Check out these two pages on my 73 911T...
http://www.geocities.com/william_armentrout/dyno_graph.html http://www.geocities.com/william_armentrout/dyno_sheet.html Bill ------------------ William Armentrout 1973 911T 2.7 carerra rs specs www.geocities.com/william_armentrout |
