davis911s's Avatar
Bench test thermostat?
How can I bench test the oil thermostat? I bought a complete set of oil lines including a thermostat and radiator type cooler a few years ago. The car has been off the road
Anyways I am finally getting around to getting the car back together and want to test the thermostat BEFORE I take the time to install it into the car.
I can't really see anything if I look inside, so I don't know if it is open or closed right now.
Ideas?
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 06-11-2009, 07:04 PM
davis911s's Avatar
Is it safe to say that if it is cold fluid should not go through, and if I heat it then it should open and fluid should go through?
Is it safe to boil it in water? as long as I make sure it is completely dry afterwards?
Shawn
77 Targa with 2.7
Old 06-12-2009, 06:51 PM
Thermostat test......
Shawn,
Are you refering to the auxiliary thermostat? A very simple test to do is immersed the auxiliary thermostat in water or oil and heat the bath. The valve will start to open at 180°F+ and will gradually continue to increase the opening as the temp. builds up. At 212°F (boiling point of water), the aperture should be wide open already. Then cool down the water/oil bath and observed the closing of the valve.
Tony
Old 06-12-2009, 07:43 PM
