930 fuel lines
Purchased a 930 roller the fuel line and pump is missing. The tank has no flared or threaded ends just two size different smooth tubes. I am going to mount the pump in the rear of the car. Any thoughts about just running High pressure rubber tubing back to the pump from the tank. I would just use hose clamps to attach to the tank. Is there anyone that makes metric fuel fittings?
Old 07-30-2009, 11:34 AM
