-   -   78 SC Won't Start? (http://forums.pelicanparts.com/porsche-911-technical-forum/479916-78-sc-wont-start.html)
psalt 06-20-2009 05:02 AM
There should be a sticker in the engine compartment showing you the cylinder order and the distributor direction. Number 1 is the drivers side (LHD) rear cylinder and the distributor turns counterclockwise (another error in the Bentley). There is a notch on the edge of the distributor for number 1 , you set the crank at TDC compression for number 1, and set the distributor so the rotor points at the notch. Usually this is about 1 o'clock when viewed from above. Be aware that there are two revolutions per cycle and two TDC's, you must be on TDC compression, both valves closed. My advice is to mark the cap tower that is hooked up to number 1. Remove the cap and rotate the crank by hand to the TDC watching the rotor rotation. If the rotor point to the notch at TDC, replace the cap and determined if the wires are incorrect going counterclockwise. If the distributor was removed, it is possible that it was installed on the wrong TDC. While you are in there, remove the felt pad under the rotor and add two drops of oil, then snap the rotor back against the spring pressure to see if the advance is free.
Did you determine there is spark ? You do not have to pull an injector to verify fuel, just crack the fitting. Pulling injectors when you do not know what you are doing is bad advice. Many times the entire sleeve will rip out the stakes and you will destroy the injector sleeve. My advice is not to pull injectors until you know what you are doing and have the parts to replace the sleeve and orings and the knowledge to properly stake the sleeve.
Paulporsche 06-20-2009 06:44 AM
1-2-3 from left side rear of car toward front; 4-5-6 from right side rear of car toward front.
scotricker 06-20-2009 07:44 AM
It runs. It runs. It runs! thanks for all your help on this thread.
S.
Paulporsche 06-20-2009 08:05 AM
So what was it, the plug wires?
TerryH 06-20-2009 08:51 AM
LOL! So the guy has an intermittent plug wire issue and unloads the car? How much was your bike worth? Did you steal this car or what? Pictures of the car are mandatory as an initiation rite.
scotricker 06-20-2009 11:24 AM
here you go, and of course it was an awesome bike. ;) http://forums.pelicanparts.com/uploa...1245522218.jpg
TerryH 06-20-2009 06:59 PM
Very nice! Looks like it was taken care of.
Drive it like you stole it.... SmileWavy
