Pierburg fuel pump
I have installed webers on my 82 SC. Even using a Mallory regulator with a return bypass line I cannot get my fuel pressure down to 4 pounds using the stock CIS pump.
As a result, I want to change over to a Pierburg low pressure fuel pump. I have found several on line, but they all have different part numbers. I want one that will fit in the stock location where my CIS pump was mounted. What part number is the correct one for the Pierburg pump. Thanks in advance. Frank |
