9elf's Avatar
915 shift fork removal help....with pics....
Hello Gentlemen.
Could you please give me some help with the removal of the 915 shift fork?
I can only see 2 pins. One on the fork itself (spring pin) and one on the lever outside (and below) the bell housing.
The only thing I can think is if the spring pin is removed from the shift fork, this will allow the shaft to be removed from the bottom.
Thank you
Craig.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 06-16-2009, 12:37 AM
Bird. It's the word...
Fishcop's Avatar
Hi Craig
Yes, remove the roll-pin at the fork, remove the circlip under the clutch arm (and the arm), then pull the shaft out.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-16-2009, 01:00 AM
9elf's Avatar
Thanks John.
Did you replace the bushing at the top of the shaft when you did your replacement or did you just re-grease the existing?
Old 06-16-2009, 01:27 AM
Fishcop's Avatar
Regreased... but replaced the black seals either end of the fork.
John Forcier
Old 06-16-2009, 03:18 AM
