Kimos's Avatar
Arrow 77 911 with orig York compressor - AC question
I skimmed through search results and assume its freon low but wanted to ask.
Have a 1977 Turbo Carrera, she rarely gets out of the barn as I have others to "drive". The AC system was gone through about 2+ years ago - all OEM York comp etc . . .We replaced hoses as need and the system was vac down and recharged with R-12. I used the AC on a rare drive in the spring (this one is a keeper I have had for years and thus a garage queen). The AC worked fine in the spring as it always has.
Now the problem. Having not driven her in a month or so thus I decided it was time and took her out. This time however the AC wont kick on. The compressor not engaging.
I assume that freon has reduced to a low level and limit switch keeping it from coming on? Do the yorks have such a switch?
A bit rusty re AC (cant remember everything I guess) I have recharged the systems on my others i.e. SC in the past and still have manifold set but it has been a while. Best method to check pressure to see if too low? and/or do I put a can of R12 in (have one and access to more) to see if compressor kicks on?
Any assistance greatly appreciated
Cheers!
"If you can create something time cannot erode, something which
ignores the eccentricities of particular eras or moments, something
truly timeless, this is the ultimate victory" - Ferry Porsche
Old 06-16-2009, 06:59 PM
