At the track = great day
ChkbookMechanic's Avatar
Thumbs up Mitch Leland's Steering Wheel Bushing
I know Mitch has talked about his steering wheel bushing in some threads but not many people have given a review of it. So I figured I'd be that adventurous soul to do so..
First some background, my steering wheel had more shaking in it than I thought was correct. Since I've slowly been turning my car into a track vehicle and was about to change out the steering wheel I decided to buy Mitch's steering wheel bushing since the time was right to do it.
His instructions were clear and easy to understand, even if installing it isn't that big of a deal. I had the old steering wheel and parts off in under five minutes. Installing his bushing is as simple as pushing it down onto the steering shaft and then using a dowel rod to push it until it stops going any further. If you're going to just be replacing the bushing I would expect the job to take 30 minutes tops.
After installing the new steering wheel I took it out for a spin and there was a noticeable difference. The steering had a much better feel and for lack of a better term, it felt "modern." There was no more shaking that I felt before, had zero play and it still maintained the road feel that I was expecting from the 911. However, you know it takes more than a single time around the block to make sure it really works well. So, I took it to one of the local tracks and ran 4 20-minute sessions to see how it felt. After the sessions, I can say without hesitation it is by far one of the cheapest and easiest upgrades you can and should make to the 911.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 06-16-2009, 07:12 PM
rhymes with targa
Bearded Viking's Avatar
How did you order the bushing? Does he have a website?
I do recall a thread a while back with him in the "testing" phase.
Old 06-16-2009, 08:03 PM
Mitch Leland's Avatar
B.V.
Check your PM mail...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-16-2009, 08:23 PM
I ordered one of these bushings from Mitch a few weeks ago but I haven't had a chance to install it. It'll be replacing the common steel bushing fix.
When I do I'll be sure to post the results!
Stay tuned...
-Scott
'87 911 turbo, '10 Cayman S
In the past - '71 T, '77 S 3.6, '80 SC, '88 3.6 cab
Old 06-17-2009, 03:43 AM
What's the difference in this and a stock replacement?
Old 06-17-2009, 03:53 AM
newb.
eimkeith's Avatar
I'd like to know as well.
keith
'75 RS/RSR-look | '67 Kaiser M715 | '73 CB750 | '70 TD250B
r gruppe #436
zuffenhaus: products|eurowerks
Old 06-17-2009, 04:06 AM
I'm sure I might miss something here but I'll describe it the best I can.
The stock steering bushing is made up of: a star washer, a cir-clip, a metal sleeve and a rubber bushing held in by the sleeve and cir-clip.
The bushing that Mitch has made only uses the cir-clip of the original steering bushing. The other pieces are not needed.
Here is a picture of his bushing from the thread I referenced in my original post:
and here is what it looks like installed (minus the cir-clip and also from that same thread):
Lane
Old 06-17-2009, 05:38 AM
I'll answer "Rustbucket's" question, however in fairness to Wayne who offers a competing product; it's not fair for me to use this forum to advance this product.
Simply this support bushing is a press fit on both the steering shaft and the inner race of the factory steering column roller bearing. The only moving parts that rub or wear on themselves is the factory roller bearings. This can only be done because of the close tolerances of the bushing.
Mitch Leland
Old 06-17-2009, 06:14 AM
83 SC
ramonesfreak's Avatar
I have one too ! Gets an A+ from me as well. Much better feel than the metal sleeve and i sleep better at night knowing there are no metal bits rubbing away at the steering shaft
1983 911sc
2013 VW GTI DSG
Old 06-17-2009, 08:42 AM
I took mine apart as my steering has too much play - up and down and around.
Here is what I found
The white bits must be the old bushing and the clip on the column must have held it on - right?
I took the star washer off but don't see a metal sleeve where is that?
The white bits that were left don't seem like enough - it looks like most of the old bushing must have slid down the shaft behind the bearing.
I've contacted Mitch for a new bushing but am wondering if I need to try to get the rest of the old bits out.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'15 Ram EcoDiesel
Old 07-05-2009, 10:26 AM
Never left, but not right
Zeke's Avatar
There is no reason to not offer the device to Pelican Parts to sell. To me, it's not a "competing" part. It's another approach.
Old 07-05-2009, 12:28 PM
lally911's Avatar
+1 for Mitch's bushing - works great on my 84 and seems like a much better solution than the metal insert.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 07-05-2009, 12:37 PM
MrScott's Avatar
Another thumbs up for Mitch's bushing.
Maybe helpful to some, I installed the bushing last weekend and found that with the wheel nut torqued to the correct spec (50NM, following Mitch's excellent instructions) there was some binding in the steering. Loosening the nut solved the problem but didn't seem safe.
Tonight I had a chance to dig into it again and after removing the bushing I noticed the bushing had rotated from it's initial position suggesting something impeding its movement. Looking down the shaft I noticed large remnants of the plastic bushing -- further down than the pieces I removed initially but high enough (I suspect) to interfere with the new bushing. I used a bent plastic card to push them down further:
Much improved; not 100% but I suspect the u-joint(s) which is a project for another day.
Absolutely no play in the steering wheel now which from what I understand is not the case with the replacement 928 sleeve.
1980 911SC
Old 09-15-2009, 07:59 PM
Mitch's steering bushing...
Adriano, thanks for the heads up.
If there was ever a problem with my bushing install, it was due to the remnants of the factory bushing getting lodged in the roller bearing or, as in your case, stuck between the steering shaft and the bearing. Thanks for your input.
I'm happy to announce that Pelican Parts has agreed to stock my bushing and will now be the sole distributor. I feel this will enable me to make it available to more Porsche owners through their catalog. I will continue to be available for technical help.
Again, thanks for your positive feedback. I appreciate it.
Mitch Leland
Old 09-16-2009, 08:20 AM
Bye, Bye.
Scooter's Avatar
What is the cost for one of these bushings???
Elvis has left the building.
Old 09-16-2009, 09:00 AM
Drivin' Miss Daisy
benzyne's Avatar
+1 for the bushing. It was an easy install in my 78 SC. Mitch is prompt and courteous. I'm glad that Pelican is now going to stock the bushing as well.
58 VW Split Window Bus - Porsche Powered
78 911SC Turbo Look - Megasquirt II, EDIS, 964 intake
92 964 Turbo
Old 09-16-2009, 09:24 AM
Administrator
Scott at Pelican Parts's Avatar
We are pleased to now feature Mitch's steering wheel bushing!
The price is $29
You can find it in our catalog by clicking this (very long) link:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=SUSstr&page=5&bookmark=23&part_number=PEL-ML-STR
Old 09-16-2009, 10:55 AM
Get one of these before you get the metal sleeve. It's worth the price, well made, and is a much better solution than the "band-aid".
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-16-2009, 12:55 PM
Shaun @ Tru6's Avatar
will these work on 69-73 cars?
Tru6 Restoration & Design
Old 09-16-2009, 02:02 PM
Wavey's Avatar
Originally Posted by Scott at Pelican Parts View Post
We are pleased to now feature Mitch's steering wheel bushing. The price is $29
Excellent! I'll be adding one to my next order.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '14 Nissan Frontier 4X4, '92 Acura NSX.
Old 09-16-2009, 02:07 PM
