-   -   power window (http://forums.pelicanparts.com/porsche-911-technical-forum/480712-power-window.html)
Andre Guay 06-18-2009 07:16 AM
power window
Is it normal that I can't operate my passenger's power window with my driver's switch when the passenger's switch is disconnected?
nesslar 06-18-2009 08:09 AM
I'm quite sure. Should be like a 3-way switch, say at the top and bottom of a stairwell. I have the wiring diagram at home, but you should be able to find it here by searching and then you'll see.
Andre Guay 06-18-2009 08:45 AM
power window
Thanks, you're right. Just found the diagram...
Black77USS 06-18-2009 09:18 AM
I had a bad passenger's window switch, and I could not operate the window until I replaced it. I tried putting the good switch from the driver's door in the passenger's door, and no go! After reading the wiring diagram, I determined both switches have to be good AND connected for either switch to work. At least this is the way it went for me.
