CIS Pressure problem
I borrowed a CIS tester and used this site
http://members.rennlist.com/jimwms/CIS/Testing/wur_specs.html 77 2.7 CIS engine Cold pressure 1.6bar (should be 0.8) valve closed System pressure (valve open) would only go up to about 0.7 when I was holding the pump on. It would drop right away to 0.1 if I let off the pump. When I connected the electrical no change I also noted that after about 10-15 attempts I could see wetness around 2 or 3 injectors . Leaking injector o ring, is this due to the number of attempts or real bad o rings? The WUR I am using was taken off a working only 6 weeks ago and has not been used? To get the fuel pump to turn on I am leaving the key "on" and pushing up on the lever inside the airbox assy Ideas? |
Correct me if I'm wrong but I would say that your motor is really full of fuel by now.
You are right.
Pulled the #3 injector out and it was like a lake it there. #3 seems to be the worst one |
I took the #1 and #3 injectors out and put them in a glass jar.
With those two in the jar the findings change Cold pressure is perfect .8 bar system pressure goes to 4.5 bar with the fuel pump on then drops to 2 bar when pump turns off. But it makes no difference when I plugged the electrical back into the WUR I have 12V at the electrical into the WUR when the pump is on |
CIS troubleshooting.......
Shaun, You are not doing the proper way/method to check your control and system pressures. By lifting the air flow sensor (ignition switch ON), you're allowing the fuel injectors to deliver fuel unnecessarily to a non-running engine which will cause flooding in the chambers. Use a suitable jumper with in-line fuse and jump-start the FP by connecting terminals #87A & #30 (FP relay socket). This method will prevent the delivery of fuel in the combustion chambers during your tests. There are numerous threads and discussions about the subject. If you still have some doubts doing the test, simply ask and there will be plenty of help available from the members. Bentley SC manual has some pictures illustrating the correct position of the CIS fuel pressure gauge valve. Control pressure ---open valve; system pressure---closed valve. The exact opposite of what you did. Keep us posted and will guide you all the way. Tony |
Tony THANK YOU . Sorry I read until 3AM last night and somehow missed the jumper cable. Damn that will be a lot of fuel sitting in the engine. Will it harm it, how should I "drain" it? Would letting it sit for a day work?
I don't think it would be a good idea to start it like that I was thinking the ball valve is CLOSED when it is perpendicular and OPEN when it is parallel. I will do the jumper cable from now on, Sorry :( Shawn |
I would also take out the plugs and turn the motor over by hand to get that fuel out of there.
Oil contamination.......
Shawn,
Depending how much gasoline has been delivered into the cylinders and amount that seeped throught the rings, your engine oil's integrity might have been compromised. Oil is cheap compared to an engine rebuild. Go check and inspect your oil and make the final decision what to do. Good luck. Tony |
Will do. Needs an oil change anyway. Oil LOOKS OK, but I would like to get this running before I do the oil change, would that be ok?
I took out the plugs and turned engine over got rid of gas in cylinders Retested using the FP relay 1.1 bar (a liitle high?) 4.8 bar no change when I plugged in the electrical connector to wur? |
@ 15C your ccp should be about .9 to 1.35 bar. Your warm cp should be 2.7 to 3.1. You have the vac assisted WUR, right? 4.8 FP is OK.
MORE PROBLEMS
Paul. YES I have a vacuum controlled WUR. Problem keeps getting worst. I thought since I had a complete set that was from a known working car I would save myself some time and swap the known good parts over. Didn't work. I swapped over the fuel distributor and the throttle body- since these both came from the running car I thought they would still be set up. Put everything in....no start :( I was able to get it to start by lifting the air flow sensor for a second thereby putting fuel into the system. But it would start and die right away. I re-checked the fuel pressures using the gauges; with the valve closed as soon as I run the fuel pump using the bridged relay the gauge needle wraps ALL THE WAY around the gauge until the stop. Obviously the system pressure is WAY too high with these "new" parts. What is going on? I am getting frustrated I know that just throwing parts on something is NOT the way to fix things but I thought since the "new" parts worked this would be easier. Also does anyone have the correct vacuum diagram for a 77 CIS? I found the one for a 78 on Jims website. The two I have had different vacuum connectors This is how I have t right now- Front ports on throttle body- top one to bottom of WUR, bottom one to Thermo time switch and t to dist (plugged). Rear smaller plugs on throttle body plugged. Vacuum control was hooked up the same on both. PLEASE HELP |
Am I confused or missing something ?
Your "system pressure" (with the ball valve closed and using a piece of wire to jump #87A to #30) should be 4.8 bar and your's is 4.8 bar -- that's normal Your "cold pressure" (with ball valve open) should be around 1.6 bar and yours is 1.6 bar -- that's normal. What's "getting worse?" piscator |
For 12v at your wur the alternator must be charging.
have you checked for return line blockage? Ive worked on two cars that were sitting for a few years, and both had a blockage at the return nipple on the tank, just a thought.
[QUOTE=davis911s;4734532]MORE PROBLEMS
I re-checked the fuel pressures using the gauges; with the valve closed as soon as I run the fuel pump using the bridged relay the gauge needle wraps ALL THE WAY around the gauge until the stop. What is going on? I am getting frustrated Make sure you doing the testing correctly. Ricks911s has a thread w/ videos or check one of my recent threads. I know that just throwing parts on something is NOT the way to fix things but I thought since the "new" parts worked this would be easier. "Throwing Parts" really refers just to buying a lot of new parts and putting them on until the problem stops. In your case, temporarilly putting some good parts on from a running car seems a good way to go about it. It is pointing out yopu may have some other issues, eg testing procedure, blocked fuel lines or vac leaks. Also does anyone have the correct vacuum diagram for a 77 CIS? I found the one for a 78 on Jims website. The two I have had different vacuum connectors Try page 46 of the 74-77 portion of the "New Parts Diagrams" PET on this site. |
Check your fuel pump pressure and as mentioned above the return line. You should be able to blow into your return line and have it bubble at the tank. You shouldn't be able to wrap the gauge if the fuel has a place to go.
That stuff ran perfectly on my car. |
Two things can cause the system pressure to be way too high: one is the pressure regulator in the fuel distributor can be mis-adjusted or frozen closed; the second is a blockage in the return line that goes from the fuel distributor back to the fuel tank. The regulator in the FD is a bleed valve/spring arrangement with shims under the spring to regulate the pressure to roughly 5.0 Bar. If the regulator is doing it's job, then the excess fuel must be free to flow back to the fuel tank for the FD regulator to be able to work. So to check the return to the tank, substitute a fuel line in place of the tank return, into a coffee can or similar. If you get flow to the can, then the fuel line to the tank may be plugged. If no flow, and gauge registers the high pressure, the blockage is in the FD. |
I had the proper pressures with my "old" parts. But I could not adjust the mixture and idle to get the car to idle under 2500. Without it stalling or running it really rich. So I changed out the fuel distributor and throttle body with ones that were removed from a known working car. Now I have these new pressure problems Quote:
I have not checked, but I did NOT swap it, and the pressures were good with the "old" parts. Quote:
If I blow into it will I hear it in the tank? And just to confirm the fuel return line you are talking about is the 17mm one that comes of the back of the fuel distributor and goes to the tank. There are two back there the one on the left side comes from the fuel filter and the one on the right side is the return? Quote:
Shawn |
I blew air into the line and could hear it bubbling in the gas tank, it is not clogged Then I used the spare return line and attached it to the fuel distributor and placed the other end into a jar. Turned on the fuel pump and there is gas flowing into the jar. So the excess is leaving the FD and the return line is not blocked. What else can cause high system pressure? I am really confused Thanks, and Happy Fathers Day :) Shawn |
The return line also goes to the bottom of the tank. You might think about sending a blast of air down the return line with your air compressor. I wouldn't do much more than 100 psi. I feel terrible about this, you should have been able to reconnect the lines I disconnected for shipping and put my system on and go. My car ran really well with that system. Scott. |
Scott don't feel bad. Like I said I am 100% confident that these parts worked in your car.
I don't think the lines are mixed up. The one on the left side is the supply the one on the right is the return. I sent a small blast of compressed air down the line and that is how I heard the bubbling and knew the line was not blocked (I used a real small air compressor and about 60 PSI) |
Is the plunger hanging up?
Plunger able to move freely
UPDATE I replaced the fuel distributor with my old one, since it showed good pressure readings. I left the air plate sensor in there, since it worked with the throttle body, therefore I assumed they were "in tune" together. New readings perfect 4.8 and 1 bar :) I was smiling thinking it would run perfect now. The throttle body and air sensor were working together. WRONG! :( Engine stated then died after 1 second. Tried to restart, it turned over then backfired (I have pop-off) I pushed up on the sensor plate to activate the fuel pump and injectors. Engine started right up then died again 1 second later. I pulled all 6 injectors (kept them hooked up) Placed the injectors in jars and disabled the ignition (plug wire) . Since it is fathers day I had my helper (4 year old son) turn the key to "Start" and watched the injectors, nothing, no fuel came out. This was about a 5 second try. So I pushed up on the air plate sensor. All 6 injectors looked good with lots of flow. Replaced injectors and tried starting again, same thing, started for 1 second and died. On re-start it turned over a few times and backfired. Pushed up on sensor plate to give injectors fuel and it started for 1 second and died. QUESTION- Should the injectors not be flowing when the key is at "Start"?? I am getting there. I am still confused by the extreme high pressure on the other fuel distributor but not concerned about that right now. Just want the car to run. I was thinking this is a lean condition. I half considered adjusting CO mixture but reconsidered because they worked together before, and I am not sure that is the problem. I am thinking it is either; 1- Injectors not firing at start like they are suppose to, or 2- It is a lean condition and I need to start adjusting the mixture and idle screw QUESTION- Should the injectors flow fuel when the key is at "Start"?? Shawn |
Checking pressure regulator
The FD regulator is really pretty simple. Fuel in, pressure builds until the valve opens at a pressure set by the spring, fuel flows around the valve and out the return opening back to the tank. Nowhere in the FD should there be any pressure higher than that set by the regulator. This includes the pressure indicated at the connection leading to the WUR. If you want to check the regulator, you can remove the plug that holds in the spring, shims, and valve with the FD in place, but you will have better control of these parts with the FD out of the car. In either case, you need to exercise care not to lose the parts. The shims are very small, and thin. You remove them to lower the pressure, and add to raise pressure. One thing that may not be obvious at first is that the thickness of the washer under the hex on the plug that holds the spring in place will also affect the FD pressure setting. If the FD remains on the car, it may be a problem to get the valve out. |
Maybe it's time to check other components like the AAV, the AAR and the thermovalve. Also check the airbox for leaks, as well as all vac lines, and the decel valve.
It sure sounds like it could be a lean condition. It could be caused by an improper mixture setting or vacuum leaks if not the FI components themselves. Are all ignition components good? How about your points? Why are you doing this? Did these symptoms recently appear? Is the car new to you? |
Your old parts may have been working OK. Did you check them with your tester before removing them? Would it worth the trouble to reinstall them to find where you issues are? |
Very well said........
Rex, I just cannot fully understand why some people recommended adjusting the mixture at this point. The 'leak condition' is obvously caused by some unmetered air going into the system. The idle screw does not do any change even at maximum adjustment. So this is an indication of 'excess unmetered air'. No CIS components could help solve this non-starting problem. Go to basic CIS troubleshooting.....make sure you have sufficient fuel pressure, correct ignition timing and decent sparks, all CIS component in spec, and no big air leak, the engine would run. The system has a MAJOR AIR LEAK !!!!. A while back, a member ( who is very acrive in this forum) had a problem starting his car and focused on the WUR. It took a very long time to convince the fellow that there was undiscovered air leak in the CIS system. Not being able to find the air leak does not mean there is no air leak (vacuum leak). There are several techniques used in locating vacuum leak/s. This should be the concentration of the work to solve this nagging no-start problem. Otherwise, it will be a long hot summer. Good luck. Tony |
For the life of me, I can't imagine who Tony is talking about!?! LOL! Actually, I never denied there was a vac leak, I just pointed out that 3 mechanics and I couldn't find one.
I had several issues w/ my car recently, including several WURs, none of which wanted to rise from a cold cp, a thin spot in the metal tube feeding the AAR and AAV that opened up into a 3/16" dia hole when prodded w/ a screwdriver, an atmo line connected to the thermovalve instead of a vac line, a small 1/8" dia port on the lower backside of the TB that was not plugged, and finally, a faulty electrical connection to the WUR. It's possible that some or all of these things, added together, produced an engine that was hard to start, and ran too lean, or started well and ran too rich. I don't really know if there was one or several culprits, but I'm glad I took the time to find all of these incorrect items. Turns out, for example, that 3 WURs I had actually had faulty bimetal strips, which could only be discerned by testing. I don't know how big a hole has to be to be called a MAJOR AIR LEAK. As I said. I found a 1/8" dia hole and a thin wall in a pipe! Hardly seems MAJOR, but apparently it was enough. Or maybe it was enough in combination w/ the other items found. Several people here are saying the same basic things, each in his own (in)imitable style: Make sure all ignition components are good, look for vac leaks, make sure the vac lines are correctly routed, test CIS components. BTW I had to take the airbox and intake runners off the engine to find the hole in the metal pipe and the open TB port, so it may take some hunting. Regarding the cold cp. I found that the ccp setting was very sensitive once it got down near the correct level. It seemed to take a large plug move to get very small or no change, and then very tiny moves to get large changes. I asked before: did this happen w/ your old CIS components? Or is this something new since installing the new ones? I haven't read anyone recommending you change your mixture. Maybe Tony spotted something I missed, but are you sure your mixture was correct to begin with? |
I agree with you guys. I have made the decision to pull the complete system off the engine. Airbox and intake runners included. I have a big airleak somewhere. I am thinking airbox or that metal pipe that Paul had the problems with. I will see once I get it all taken apart.
The "used" system was tested before I bought it. It ran well on his car and it is actually his pressure tester that I have. He lent his tester when I bought the parts so that I could get my car going. I will keep you guys updated Shawn |
Shawn,
Did you get it figured out yet? |
Scott
Not yet, I have not had a chance to work on the car. I just got an airbox tester in the mail from CIPOTIFOSO , two days ago. I will be testing the two airboxes next week. Sorry I have been preoccupied trying to get my old VW bus running. It is my daily driver so more of a priority right now |
when you lifted the sensor plate and started it, did you hold it up to try to keep it running? did you have the dizzy out before you started any of this? |
i dont think he was suggesting to adjust the mixture. he said to tutn the IDLE screw in. i have done kinda the same thing with carbs. i put my hand over the top to reduce the air intake to see how much or if the idle changed, a big air leak and you could almost competely cover a carb intake and it keeps running. but now that i think about it, if he has swapped parts, the mixture may need to be set. if he has no air leaks, i would try to get it running by holding the air plate up, even after it has started, and adjust the mixture to keep it running. he has not said, or i missed it, what else was done before this. anything with the timing? |
I Also have a 2.7 CIS with almost exactly the same symptoms.
I am also trying to debug the same issue. Could i ask when you switch on the ignition does the fuel pump run constantly ? ( Mine does and i'm not sure this is correct ) Cheers Martin |
the FP should not run when the engine is not running. if it is, the first thing i would check is the electrical plug on the back of the air low meter. if it is removed, the FP will run, this is also a good way to make the FP run when doing pressure checks.
Depends on whether or not your car has the air flow switch....or if it is bypassed.
| All times are GMT -8. The time now is 09:15 PM. |
