Born to Lose, Live to Win
AC fan question
since i got my car the fan knob for the AC fan has not worked. I removed the rear compressor long ago.
I must have left the AC fan knob in the on position and today, when i pulled up on my heater levers between the seats like i do everyday, the AC fan came on for the first time and at the same time that i pulled up on the heat 2 questions: 1) are the heater levers connected somehow to the AC fan switch or was this a coincidence? 2) is it ok to run the AC fan even though the rear compressor is not hooked up? im getting a decent flow of air and i would like to use it from now on thanks
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
I know of no relation between the two systems. Are you sure it's the evap. blower in the smugglers box that comes on? That fan just pulls air from the floorboards and blows out the dash vents. Ok to run I think but you are just recirculating the air. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
thanks. im not sure where the air comes from but a lot of air is coming out of the two vents in the middle, above the radio
