Guest
Posts: n/a
Best tires for 14" RIMS?????
Does anybody have any idea how hard it is to find a GOOD set of tires for 14" Rims
I will eventually upgrade to 16" but not enough $for that this year. What are some good options in this range, I want Z rated if possible, and what size shouls I use? Thanks all, for everything Shawn |
Guest
Posts: n/a
Shawn,
Best I could find are Michelin XGT H4 in 225/60HR-14 at Tire Rack. I'm sure they would be adequate until you get the 16ers. ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Go to www.tirerack.com they have a search engine that shows most of the Z rated tires in the rim size you need.
Good Luck. |
