-   -   setting mixture, jumper which ports to make car ignore o2 sensor? (http://forums.pelicanparts.com/porsche-911-technical-forum/481768-setting-mixture-jumper-ports-make-car-ignore-o2-sensor.html)
dimeified 06-23-2009 08:04 PM
Hi guys,
I am setting my mixture on my carrera, and instead of unplugging the o2 sensor, i was wondering which test ports under the rain guard on the left side of the engine bay i could jump with a paper clip to have the motronic system ignore o2 sensor input?
WoodSport 06-23-2009 09:09 PM
1 o'clock and 6 o'clock are the positions to jumper in order to remove the idle control valve from operation when adjusting the mixture. Is that what you're looking for?
dimeified 06-24-2009 06:31 AM
No, not that one, i'll do the idle speed adjustment after. The one i need is to ignore the o2 sensor input as if it is disconnected. I read somewhere on here that it was possible but didn't read which ports to jump.
cgarr 06-24-2009 07:00 AM
Near the bottom of this PDF file it shows the jumpers to use on the plug in the engine compartment: I understand this bypasses the O2 sensor from what Steve told me, maybe not? From SW site:
http://www.911chips.com/C1INSTR.pdf
dimeified 06-24-2009 11:23 AM
Those instructions are also for the idle speed.
TT Oversteer 06-24-2009 11:55 AM
Isn't it just as easy to unplug the connector?
dimeified 06-25-2009 08:03 AM
Its a bosch universal connector with 3 seperate posilock connectors, with pressure weather proof plugs to keep water out but let air in, its supposedly a proper replacement for the crumbling stock motronic connector. It would be easier to just jump 2 socket terminals. FML.
