#147 of 2096
How to install a 901 in a 1972
Hi,
I'm going to install a 901 and a 2 lt engine in my 72 and I need to mate the 72 shaft to the 901 transmission. I have a 911 transmission outer shaft couplers but would need to machine the part to fit in the 901. Have someone done this? I did a search but not great info. Maybe iam using incorrect words on the search tool. Please advise.
I have 2 different sets of the transmission coupler, both sets are 4 bolt 2 studs course spline type but one set is about 1/8 of a inch shorter.
Please advise,thanks
Old 08-27-2013, 04:02 PM
Under the radar
Trackrash's Avatar
Check this link.
CV Joint and Axle/Half Shaft Compatibility
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-28-2013, 12:30 PM
AutoBahned
RWebb's Avatar
you will need an adapter/shim if you use a 915 type crossbar
Old 08-28-2013, 12:31 PM
Banned
Just curious, why are u doing this install?
Old 08-28-2013, 01:19 PM
#147 of 2096
Hi, it is temporary. Until I finish my 3.0
Old 08-28-2013, 07:29 PM
Under the radar
Trackrash's Avatar
Will you be keeping the 901 trans with the 3.0? Seems to me, sourcing a 915 and selling the 901 would be the way to go, everything considered. Especially if the trans you are installing is one of those 901/911 transmissions with the weak ball pivot.
Gordon
Old 08-29-2013, 07:44 AM
AutoBahned
RWebb's Avatar
the 901 & 911 transmissions have a nicer, lighter feel to them than the typ 915
more importantly, they have the wonderful road-racing shift pattern - the 2 to 3 shift is right in a straight line, perfecto, just what you want, etc.
I would keep the 901 in there "temporarily" until you blow it up
Old 08-29-2013, 11:36 AM
