External oil thermostat - how does it work ?
Mostly out of curiosity, how does the ext oil thermostat on a 74' 911 works ?
Pressure ? Viscosity ? Bimetal sensor ? |
It responds to oil temperature. There's a special material spring in the valve whose force changes with temperature.
As temperature increases, more oil is directed to the cooler. In valve-speak, it can be called a modulating 3-way valve. |
| All times are GMT -8. The time now is 12:14 PM. |
