effvee's Avatar
915 Hydraulic throw out bearing
Hello, does anyone know of a company that sells hydraulic throw out bearings for the 915 trans?
Old 06-27-2009, 04:53 AM
Hyd. T/O
We are working on one for our flywheels and race clutches,the problem for the 915 is there is not alot of room, a 2 disc 5.5 will work but 3 disc does not have enough room, WEVO has a unit that will bolt to the late style 915 (removeable tube) and we have several that work fine. take a look at our web site there might be something you can use.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 06-27-2009, 08:18 AM
effvee's Avatar
I sure hope
Hi Mike, thanks for your response. At this point I need to further supply you with some more info. I am a type IV Super Beetle driver, but I am using a 915 trans in my application. I bought a Porsche 914 flywheel from Kennedy along with a 6 puck clutch. I have held off until I address the throw out bearing issue before I get a pressure plate. My trans has a removable throw out bearing sleeve. I will be using a single clutch. I know you can't really answer the type IV four cylinder to 915 clearance issue, but if you believe there might be a possibility I'll will contact you.
Thank you very much
Old 06-27-2009, 01:04 PM
Bird. It's the word...
Fishcop's Avatar
Have you tried AP? http://www.apracing.com/info/index.asp?section=Release+Bearings_983
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 06-27-2009, 03:54 PM
