engine wont turn off
Hi, had the plugs changed to a hotter plug in my 3.2 carrera, when i got home from the mechanic, the engine wont turn off even when i turned the ignition to off several times, any one had similar experience? thanks rommy
Old 06-27-2009, 09:40 PM
1984-911 M491
Trog's Avatar
Does you BATT charge light stay illuminated while the engine is running? If yes, then it's a good chance that your diode has burnt out:
1984-911 TLC......SOLD
Old 06-27-2009, 10:39 PM
Zeke's Avatar
Will it stop while it's still cold? If so, blame the plugs for dieseling.
Old 06-28-2009, 06:40 AM
dshepp806's Avatar
ignition switch?
Does the car stay running forever?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-28-2009, 02:02 PM
Hi to everyone, sent the car back to the mechanic when the engine did not want to turn off. The batttery terminal was removed to turn of the engine.
The dashboard lights were not on and looked normal.
The engine will not die down at all and there was no noticable change in the idling or roughnest in how the engine was idling.
Will ask mechanic to look at the ignition switch.
thanks to all, rommy
Old 06-28-2009, 09:40 PM
