-   -   2.7L to 3.2L with G50 conversion - just starting, need tips... (http://forums.pelicanparts.com/porsche-911-technical-forum/482426-2-7l-3-2l-g50-conversion-just-starting-need-tips.html)
baruch mor 06-28-2009 02:22 AM
2.7L to 3.2L with G50 conversion - my project including pictures
Its time... after spending too much money on the engine n trans - now its time to invest on the rebuilt itself!
i will start this thread for me and fo those who thing to convert their old engines n trans to 3.2 with g50.
for now what i can tell u is the prices i payed for the parts n job to be done and would like your help n tips as my mechanic doing this job on the first time.
engine+gear+pedals=8000usd
renew the gear + shorthen it = 5500 usd
job to be done (estimation ) = 1500 usd
beside the engine n trans i spent on :
4 new tires - and want to know the max size i can get there (differend thread)
new front oil radiator screen
adding booster to the old brakes
and a loot of other extras - another few $$$$$ ...
please try to give me links to other conversion threads+tips and on my side ill give u as much info as i can get + pics every day and let u know where i got problems and how we solved them (i wish there will be no problems but i know that in this kind of job "murphy rules" are working well )
baruch mor 06-28-2009 02:42 AM
just to make things easier here's a few links:
http://forums.pelicanparts.com/porsche-911-technical-forum/418536-dear-diary-my-3-2-conversion.html
http://www.pelicanparts.com/MotorCity/marcesq1/
http://www.patrickmotorsports.com/special/31/
pics will come later
baruch mor 07-15-2009 05:59 PM
as i promised , i started with the booster as its a 76 pre booster car:
http://www.pic.co.il/Files/209FD5C42...8E38D74B2D.JPG
http://www.pic.co.il/Files/209FD5C42...88EC2FEC6C.JPG
now from the bodywork shop to the mechanic to start with the engine n gear.
any tips are welcome here
baruch mor 07-15-2009 06:08 PM
i also bought a full 965 widebody kit with fiberglass bumpers and 16" wheeels .
waiting to pelicans comment what suspension bushings i need as want to change the tie rods and bushings in the front n rear suspesion. how can i check the size (diameter?) of my sway bars?
baruch mor 07-15-2009 06:28 PM
pics from the arrival of the engine n trany
http://www.pic.co.il/Files/209FD5C42...161340F02D.JPG
http://www.pic.co.il/Files/209FD5C42...B8594F7DAA.JPG
the sheetmetal from the donor car for the booster
http://www.pic.co.il/Files/209FD5C42...9D31794B00.JPG
http://www.pic.co.il/Files/209FD5C42...6761D53F3F.JPG
http://www.pic.co.il/Files/209FD5C42...793071C405.JPG
http://www.pic.co.il/Files/209FD5C42...DE794A19B3.JPG
booster
http://www.pic.co.il/Files/209FD5C42...FC1772EB35.JPG
http://www.pic.co.il/Files/209FD5C42...C7311C8C92.JPG
shifter and axels
http://www.pic.co.il/Files/209FD5C42...59AAEA2E5B.JPG
http://www.pic.co.il/Files/209FD5C42...4AF9FC4DE0.JPG
baruch mor 07-15-2009 06:31 PM
http://www.pic.co.il/Files/209FD5C42...FB599E8641.JPG
http://www.pic.co.il/Files/209FD5C42...E7352E1433.JPG
http://www.pic.co.il/Files/209FD5C42...E2EF3B4BC4.JPG
http://www.pic.co.il/Files/209FD5C42...4A6EBFCA4A.JPG
thanks to great service from rick's european connection from miami all the goods arrived in very good condition and a lot of info n pics on how to do things , aslo helped me a lot by phone calls and emails
euro911sc 07-16-2009 08:02 AM
You forgot pics of the car ;)
I realize that you are in Israel and the market is scarce there, but why not just buy a g50 car to start with? You might even be able to get all the work done here and ship the finished product for less... maybe I'm off a little.
Will be a fun project!
Best regards,
Michael
CBRacerX 07-16-2009 08:13 AM
Good luck! G-50 install will require some real work on the body side.
baruch mor 07-16-2009 04:00 PM
not too much when u use patrick motorsport idea
CBRacerX 07-16-2009 08:50 PM
That would be great if there is an easy solution as a result of shortening the bellhousing. I have an '87 with the same transmission you are installing already in place. The torsion tube is heavily changed from prior years - there is a big notch for this larger G50 gearbox to fit, and as a result the torsion bars are relocated outward. In addition, the rear seats have a larger relief between them.
baruch mor 07-18-2009 02:05 PM
:confused::confused::confused::confused::confused: :confused::confused::confused:
so cbracerx , its not just dropping the engine and transmission and use the tansaxle carrier mount to fit the g50 to the 1976 ? im in a big problem here as i tot that is it - can u give me more details?
nobody mentioed that i need to change the torsion tube or relocate the torsion bars.
and btw what do u mean when u say "clone" like 911rsr clone or rs clone? !
CBRacerX 07-18-2009 11:14 PM
I believe that when you shorten the bellhousing most if not all of the customization to the torsion tube is no longer required. Patrick Motorsports knows their stuff so just listen to them :)
baruch mor 08-17-2009 05:04 AM
working now on the installation of the tranny n engine i have a problem that the tranny is touching the torsion tubes in the middle
what can i do now? patrick told me it will never happen - is it someting i need to know?
http://www.pic.co.il/Files/E916B375F...8B47A07300.JPG
it even touch on the back of the car but i cut it as u can see
http://www.pic.co.il/Files/E916B375F...0C6911546D.JPG
and here is the major problem - the marks in white is the where the parts touch each other
http://www.pic.co.il/Files/E916B375F...287113D81B.JPG
http://www.pic.co.il/Files/E916B375F...2ADC1B13E4.JPG
