Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 9 votes, 4.44 average.
911T '72
DeRRis's Avatar
Dennis
Good drivers have dead flies on the side windows. (Walter Rhrl)
Old 07-09-2017, 01:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2041 (permalink)
1stgear's Avatar
1985 M491 Carrera /Turbo-Look Registery #1727 / White Gold Metallic / Leather Recaro Pole Positions / Wevo shifter & shift joint / Fifteen52 Outlaws - 15x8 & 15x10 / Fabspeed RSR Headers and Muffler / AC delete / Appbiz RS Carpet Kit / Lakewell dash / Stratton Duck w/Al Kosmal grill / Elephant Racing 19mm spindles, coilovers, and quick-change camber plates / SW chip & throttle body
Old 07-17-2017, 01:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2042 (permalink)
Originally Posted by Turboo934 View Post
Where are these bolt on flares from?
Jimmy Foster
78 911 SC
Old 07-17-2017, 04:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2043 (permalink)
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by 1stgear View Post
NICE. What wheel sizes, tires and spacers?
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-18-2017, 07:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2044 (permalink)
1stgear's Avatar
Thanks. 15x8 front & 15x10 rear. Running 5mm spacers on the rears to give it the stuffed look. No spacers on the front.
Old 07-19-2017, 08:32 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2045 (permalink)
1983 RHD SC 3.0
1994 RHD E31 850 CSi
Old 07-19-2017, 11:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2046 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
wheel offset and tire type and size too? im thinking of running 235 50 15 in front on 9x15... cant find tires that are for 11x15 outside of $$$$ TBs, corsas or hoosiers
Old 07-19-2017, 03:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2048 (permalink)
1stgear's Avatar
225/50 Toyo Proxys on the front
275/50 Nitto NT555R on the rear
Front Wheel Specs: 15x8, 5x130, et10.6, 71.6cb
Rear Wheels Specs: 15x10, 5x130, et-5, 71.6cb
I may try the TBs on the next go around. For now, this setup is working great and is MUCH cheaper.
Great looking car, tpweiss!
Old 07-20-2017, 05:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2049 (permalink)
suckho's Avatar
Porsche 911 SC Coupe (1982, RoW, Zinnmetallic)
Old 07-20-2017, 07:06 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2050 (permalink)
i have a m491 too. do you get excessive under steer with the 225 in front under full throttle with the larger rear 275?? im trying dial out the understeer and too much forward brake bias. may play with the bars next and dampers
your set up looks so right with the deep -5 in the back! thanks for the sharing
Old 07-20-2017, 07:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2051 (permalink)
jmpowers's Avatar
-John
1987 Targa -Diamond Blue Metallic
Old 07-20-2017, 10:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2052 (permalink)
1stgear's Avatar
Thanks for the props, Panzer! Every time I walk to the car I thank myself for going with 15s and going deep. All that chubby rubber looks mean as h3ll.
I have no under steer at all. Check my sig for my front suspension setup. Im running 7 250 lb. springs on the front with 1 degree of camber. She's not as nimble as a narrow body, but handles MUCH better than stock.
Old 07-20-2017, 01:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2053 (permalink)
ok i will search out your set up... thanks!
Old 07-23-2017, 02:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2054 (permalink)
1stgear's Avatar
Talk to Chuck at Elephant. He'll get you taken care of.
Old 07-24-2017, 05:39 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2055 (permalink)
yes, ive driven a full 930 with bronze,through bar, rear ASP, custom bils or vons on 255/315 steamrollers.... nothing sort or a remarkable transformation!
Old 07-24-2017, 07:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2056 (permalink)
83 sc
1983 SC
Old 07-25-2017, 07:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2057 (permalink)
That Guy
Techno Duck's Avatar
Here is my '88. All Elephant Racing rubber, 22/29 hollow torsion bars. Wheels are Lindsey modded Fuch's, 17x8 and 17x9.5 with 225/255. I bought these wheels from a friend, otherwise i probably would have gone for 17x7 and 17x9...they looked too good on the test fit to take off again .
Ive put about 1k miles on this setup and have gone over some pretty nasty bumps with no issue. Go figure it was crawling into a parking lot at 2mph where the tire scraped the front fender lip just a little. I rolled the front fenders just slightly which i think was enough, but I plan to roll them a little more this weekend just in case. The rears...well they fit barely but i haven't had any rubbing at all. Alignment is nothing crazy, -.4 degrees front and -1.5 degrees rear. With that said, i would not feel comfortable doing an auto-x with this wheel setup...and even for a track day i would probably put my stock 16x6 and 16x7 combo back on for fear of damaging a front fender.
Jon - San Diego PCA #516
1988 Granite Green 911 3.4L
2017 Reflex Silver Mk7 GTI
Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1, 1997 E36 M3, 2003 E39 540i
Old 08-06-2017, 09:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2058 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
Looks pretty sweet. Love the colour. What is that, granite green?
I don't think I'd worry about tire clearance once you get your front fenders rolled. It looks like there's adequate clearance on the rear as is. My Zuffenhaus wheels are 9.5rr and 8.0fr, I believe. No idea of the offsets, however.
Kevin
Old 08-06-2017, 11:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2059 (permalink)
hank911's Avatar
HankP
1976 Targa
BMW R100RT&RS
Horizontally Apposed
Old 08-07-2017, 02:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2060 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
