fred cook's Avatar
Horsepower Estimate...............
I am planning a rebuild on my 1980 SC 3.0 litre engine. The configuration that I am considering will be:
98 mm Pistons and Cylinders 10.5:1 compression (3.2 short stroke)
"S" or 20/21 cams
Twin plug heads with direct fire ignition (no distributor)
PMO 46 mm carbs
Given these factors, approximately what HP should I expect the engine to develop?
Also, how much HP would the same engine make using 3.2 or early SC heads with the larger ports?
Last question: Name of a shop that does the twin plug conversion in the Atlanta, South Georgia or North Florida area?
Thanks,
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-05-2009, 06:53 PM
Super Moderator
cstreit's Avatar
Probably 245HP I would guess... (give or take 10HP) your exhaust choice will also impact this.
Why would you stay with a 20/21 cam if you are replacing the pistons and using carbs? The only reason for a 20/21 cam is because of the compromise required with the CIS system.
A GE40 cam or similar profile would make sense for this engine (street) or GE60 (track) and take better advantage of your investment.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-06-2009, 01:05 PM
fred cook's Avatar
Cam Choices...........
Thanks for the camshaft suggestion. What about the "S" cams? I have read that they will provide good power and with 3.2 ltrs of displacement not exhibit the peakiness exhibited in a 2.0 or 2.2 ltr engine.
Thanks,
FEC3
Old 07-07-2009, 09:55 AM
Super Moderator
cstreit's Avatar
S cams are a good cam, but there may be some that are better. I'd talk to John at DR Camshafts (pelican member) or WebCams about your specific application.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 07-07-2009, 11:02 AM
With a proper exhaust system and a 7300 RPM redline you should be able to get 270HP or so. A GE40 "mod S" cam would be nice.
-Andy
Old 07-07-2009, 11:07 AM
