MSD 6AL for an 87 Euro 911??
Thinking about upgrading the ignition on my 87 911. I've read a lot on our host's site here about the MSD 6AL being the right choice for an upgrade for my year car.
I wanted to ask for an update from everyone if this is still the preferred choice. Thanks in advance for your advice.
- Sean '87 Carrera |
It's a fine choice, apparently much more reliable that a Permatune, and hugely cheaper than a Bosch replacement. Don't expect to find a smoother more powerful engine though; it pretty much just does what the Bosch did before. So I'm not sure I'd call it an upgrade, more like a replacement. (Others will tell you that it made a remarkable difference for them; I've never seen it.)
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
The Puff.
It may depend on the condition of your ignition. Pairing the MSD up with a blaster coil is a good idea
'70 CT1B '11 GTS 300 Super |
Thank you both for your comments/suggestions.
I now see the Blaster Coil as two types; Blaster 2 and High Vibration. Which would be the correct one for these cars?
sudo apt-get purge 930
High Vibration.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Thanks Mark...
Now, anyone know where some detailed MSD ignition instructions for a 911 might be found... I found some for a 914 and an older 911T, but nothing around an 87.
Anyone?
The Puff.
The installation instructions should be in the tech articles.
--Puff |
MSD on an 87 911? Won't work as that car uses Motronic, not CDI.
Where was jp911 when we needed him?
Snap, I thought I was in the turbo section. Doh!
Here's a question to ponder....just what kind of Porsche ignition sub-standard condition are you trying to solve?....
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
