-   -   Intake #2 wiring connection (pic) (http://forums.pelicanparts.com/porsche-911-technical-forum/483814-intake-2-wiring-connection-pic.html)
jmiemiec 07-05-2009 11:54 PM
Hi,
on Intake #2, there is a wiring connection. Where should this go? I remember this being indirectly connected to the coil.
2.7s
thanks for your input.http://forums.pelicanparts.com/uploa...1246863084.jpg
jmiemiec 07-12-2009 09:02 AM
Anybody?
Should this go to positive or where? I have no CD so gotta be coil + or temp sensor? A bit lost here... thanks!
stlrj 07-12-2009 10:39 AM
Any 12V ignition source.
jmiemiec 07-12-2009 10:53 AM
Thanks Stlrj! I am getting myself confused since I "refreshed" the wiring. Can I clarify one more:
* I currently have this connected to one of the two wires for the Oil Temp Sensor (chain housing). These two appear to be going to the mail/femail connection close to the breather hose.
Q: should I disconnect this wur wire from the oil temp sensor and connect it to coil + or any 12V source instead? Aren't these two connections (oil temp sensor & wur) related??
stlrj 07-12-2009 05:04 PM
You will need a 12V test light to see if you are getting voltage when the key is on.
