ebenstein
Guest
Posts: n/a
Will a set of y2k 996 rims fit a 911- any year?
Will a set of y2k 996 rims fit a 911- any year? I am considering an upgrade.
Old 02-06-2001, 06:53 AM
Mikkel
Guest
Posts: n/a
The 996 wheels only fit 964s and 993s. Pre 964 911s have different offsets.
Old 02-06-2001, 08:08 AM
ebenstein
Guest
Posts: n/a
Can spacers or adapters compensate for the difference or are they totally incompatible?
Old 02-06-2001, 09:25 AM
orbmedia
Guest
Posts: n/a
You can use spacers but they would be huge (over 30mm) and not approved by Porsche. Also, the wheel would stick out too far. I have not done this but I think others have done it with mixed success.
Old 02-06-2001, 11:03 AM
ebenstein
Guest
Posts: n/a
hERE ARE EXACT SPECS OF THE WHEELS i WOULD REALLY LOVE TO USE WITH MY 911 THAT i AM REBODYING TO A 993 STYLE.
WHEEL & TIRE SIZE IS 8X18 FRONT WITH PIRELLI P-ZERO 225/40ZR18; REAR 11X18 WITH PIRELLI P-ZERO 295/30ZR18. OFFSET FRONT ET50 REAR ET45. FRONT PART # 996-362-136-04 & REAR PART # 996-362-142
I WOULD LIKE TO KNOW EXACTLY WHAT IT WILL TAKE TO MAKE THESE WORK IF AT ALL.
THANKS A MILLION.
KENNETH 73 911 CONVERSION PROJECT.
Old 02-07-2001, 07:56 AM
orbmedia
Guest
Posts: n/a
Those look like 993 widebody offsets. Are you sure it's 11x18? I'd think it was 10x18. In any case I'm going to say you'll need at least 40mm spacer in the front and 30mm in the rear. As a result these wheels will stick out alot from the wells and the large front spacer will not be safe. TUV and Porsche only allow 30mm max on road cars. Perhaps someone who has done this can comment?
[This message has been edited by orbmedia (edited 02-07-2001).]
Old 02-07-2001, 08:47 AM
ebenstein
Guest
Posts: n/a
Is there anyone out there that has done this?
The auction ends soon and want a second opinion.
Old 02-07-2001, 08:31 PM
pacmyster
Guest
Posts: n/a
I have oversized wheels on my Porsche..
It's a 77. I have 18x8's up front and 18x9's in the back... The front wheels should fit with some simple adjustments but my rear wheels are flush with the fenders and there is only 3/4 inch clearance between the inside of the wheel and the fender wall. I can't imagine a 10 or 11 inch wheel would fit unless you went with Turbo flares and an outrageous spacer.. I run 225/40/18's up front and 255/35/18's in the back..
Hope this helps.. It's not really apples to apples...
Pete
77'Carrera3.0
www.geocities.com/pcafaro2000/carrera30.html
Old 02-07-2001, 08:47 PM
Mikkel
Guest
Posts: n/a
It's possible to buy aftermarket Porsche replica wheels with correct offset in 18 inches. Maybe that could be an option for you? I know that you can get the Cup2 wheels in 18 inches and probably also the twist spoke wheels plus of course the Turbo 3.6 looking split wheels.
Old 02-08-2001, 06:20 AM
