-   -   banjo fitting on mc (http://forums.pelicanparts.com/porsche-911-technical-forum/484228-banjo-fitting-mc.html)
robotman 07-08-2009 09:26 AM
banjo fitting on mc
Can i reuse the banjo fitting brass washer on the master cylinder or should i get a new one. I cant find on this site where to order it. Also does the banjo fiting go on the mc and then this washer and then the final brake line.
JerryL 06-03-2010 06:57 AM
When you describe putting it together and say "this washer" ect lets try a pic and what yr. are you working on?
Most all banjo fittings use 2 crush / sealing washers replace them every time.
You should be able to match them up based on the ID & OD sizes, tey a motor cycle shop or local AP store, on the brakes DO NOT use aluminum sealing washers, go copper.
Regards
Shoepop 06-03-2010 08:10 AM
Yes you can reuse run them over a piece of 300 + grit sand paper both sides it will take the ridges off nicely. Jerry is correct 2 washers per fitting. One first goes over bolt then install brake line then the other washer. In other words the washers sandwich the oil line.
john walker's workshop 06-03-2010 08:21 AM
if it seals, then yes it will work.
