banjo fitting on mc
Can i reuse the banjo fitting brass washer on the master cylinder or should i get a new one. I cant find on this site where to order it. Also does the banjo fiting go on the mc and then this washer and then the final brake line.
When you describe putting it together and say "this washer" ect lets try a pic and what yr. are you working on?
Most all banjo fittings use 2 crush / sealing washers replace them every time. You should be able to match them up based on the ID & OD sizes, tey a motor cycle shop or local AP store, on the brakes DO NOT use aluminum sealing washers, go copper. Regards |
Mark S
Yes you can reuse run them over a piece of 300 + grit sand paper both sides it will take the ridges off nicely. Jerry is correct 2 washers per fitting. One first goes over bolt then install brake line then the other washer. In other words the washers sandwich the oil line.
if it seals, then yes it will work.
