The Puff.
Mr.Puff's Avatar
Finished my fuel tank resto.
Check it out guys,
I had a leaking fuel tank with a rusted seam all the way around. So I wire brushed off the rubber (on my grinder), Por 15'ed the inside, primed the thing, and covered it in some stuff called "Blue Magic Pure Rubber Coating" (2 cans).
Blue Magic: http://bluemagicusa.com/index.php/blue_magic/products/108
Por 15 Kit: http://www.por15.com/FUEL-TANK-REPAIR-KIT/productinfo/FTRK/
It turned out nicely .
'70 CT1B
'11 GTS 300 Super
Old 07-28-2009, 02:29 PM
Friend of Warren
Wow, looks great!
Kurt V
Old 07-28-2009, 02:40 PM
a.k.a. G-man
Geronimo '74's Avatar
Really nice, looks like a fun project to do.
Old 07-28-2009, 02:51 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Very nice! Where did you get the foam strip and how did you glue it on? I have my tank in epoxy primer right now awaiting a coating of grey Wurth shutz...
Gary R.
Old 07-28-2009, 03:28 PM
The Puff.
Mr.Puff's Avatar
Thanks for the positive feedback guys .
The foam strip is available on Pelican with a self-adhesive backing. Search for "fuel tank seal" in the parts section.
That grey Wurth Shutz should look very nice, OEM style.
'70 CT1B
'11 GTS 300 Super
Old 07-28-2009, 04:16 PM
DW SD's Avatar
Gary,
NAPA has a pickup truck bed cover foam gasket you can use. It has a glue strip which you just peel back to expose the glue.
Nice looking tank!
Did you do new schutz or just cover the old?
Doug
1971 RSR - interpretation
Old 07-28-2009, 04:21 PM
Tom '74 911's Avatar
Nice job on the tank. Have you posted another thread about your car? I see it's at least partially stripped in the first photo - I'm curious about the process you used to get it down to bare metal. . .
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 07-28-2009, 04:54 PM
The Puff.
Mr.Puff's Avatar
Tom
I used a wire brush and an abrasive disk. Dewalt sells an attachment for abrasive disks for a normal electric 3/4" grinder. Chemical strippers aren't strong enough to get through all of the paint and bondo.
'70 CT1B
'11 GTS 300 Super
Old 07-29-2009, 10:37 PM
The Puff.
Mr.Puff's Avatar
Originally Posted by DW SD View Post
Gary,
Nice looking tank!
Doug
I did all new schutz. The old stuff had rust under it and was coming up on the tanks seam. Getting the old rubber off is annoying, but a wire brush makes it go by faster. It is also beneficial to remove as much rubber as possible with a chisel.
'70 CT1B
'11 GTS 300 Super
Old 07-29-2009, 10:39 PM
(the shotguns)
berettafan's Avatar
wow that really looks nice. very clean and tidy!
Old 07-30-2009, 06:08 AM
razordug's Avatar
That looks Killer.......
Gonna do mine in a couple of weeks.
A local radiator shop wanted $400.00.
Any more tips Mr. Puff?
Old 07-31-2009, 06:00 PM
