R Gruppe#756
ID crank and rods also dist.
I have two crankshaft's one has rods..... these are the #'s on the first one
.930102015 this #'s also on it D743244 rod #'s are 9301031050R second crank 901102011(or77)0021 this #'s also on it D4396600 second crank has no rods. I also have a brand new dual cap dist. part#930.602.015.01 I'm looking find out what this stuff is worth. thanks for any help in advance.
R Gruppe#756
bump
The first crank is a 3.0, depending on the flywheel area, 3, 6mm threades holes to retain the pilot bearing it is 80 to 83.
No holes for the pilot bearing its a 78,79 The 901 crank is a 2.0/2.2 from 64 to 71 If it has counterbalancers it is 65 to 71, not T without counterbalancers, its a T crank The value is what ever the traffic will bear and what makes everyone content with the price Bruce |
