-   -   I.D. Engine and Trans? (http://forums.pelicanparts.com/porsche-911-technical-forum/484371-i-d-engine-trans.html)
c0metdot 07-08-2009 09:21 PM
Is there a preferred online I.D. resource for engine, trans, chassis numbers and info?
Hard to buy parts when you dont know what you have.
Web good. Rather not buy the book.
Eng: (star) 6198055 (star)
Trans: 901.301.101.0R
In a 67 911 coup.
http://forums.pelicanparts.com/uploa...1247113087.jpg
Thanks for the look.
tonythetarga 07-09-2009 06:00 AM
1969 T.
http://www.elferhelfer.com/fzident.htm#
Its in German the numbers are the numbers in either language.
The trans number looks like a casting number.
djpateman 07-09-2009 06:19 AM
Engine type 901/19 from 6198001 to 6198184, so that is one of only 184 USA version 911T engines for Sportomatic transmission. See my thread here to find the build # on the case:
http://www.early911sregistry.org/forum/showthread.php?t=24913
This build # would be very useful for my research since I have no example of the type listed.
The transmission # is located on the bottom rib under the differential. All serial #'s are stamped into the cases (recessed) as opposed to raised cast in numbers that are generally part #'s.
I'd like to know more about your 1967, especially the VIN and the paint code stamped into the paint badge. I research the paint codes also.
c0metdot 07-09-2009 08:11 AM
Thanks for the help.
Trans Stamps:
http://forums.pelicanparts.com/uploa...1247151511.jpg
VIN:
http://forums.pelicanparts.com/uploa...1247151581.jpg
http://forums.pelicanparts.com/uploa...1247151959.jpg
c0metdot 07-10-2009 09:29 AM
The build number:
901/19
18585
