Allignment Question
I'm hoping someone can provide some perspective for my 1980 911 SC.
I had new tires mounted in the rear last week and got an allignment. My car handled fine before the allignment and tires. It tracked well on center and was very linear and predictable on turn in and rotation. Right rear tire wear was slightly accelerated compared to left rear. Fronts tire wear is balanced. After the rear tires were mounted and the allignment was changed, I noticed a significant change - not good. On center, the car hunts. Every road surface imperfection cause the car to move left and right - requiring a minor correction with the wheel. It doesn't feel stable. Turn in is instantaneous and exagerated. As soon as the steering wheel is turned, the car darts that direction and the back rotates a LOT harder than it did in the past. Instead of a progressive rotation, I can feel the tires and suspension load up instantly and the car becomes a lot more sensitive to throttle steer. I noticed that with a full tank of gas, the problem is less pronounced than with an empty tank. Here are some details to work with: Stock setup with 190K miles Front strut bar Turbo Tie Rods Closer to Euro than US ride height Front tires are Toyo Proxis 4 with good tread depth @ 30 lbs Rear tires are new Toyo Proxix 4 with 34 lbs Front Left Caster went from 6.4 to 6.6 Front Right Caster went from 6.4 to 6.8 Front Left Camber went from -0.7 to -0.8 Front Right Camber went from -0.5 to -0.6 Front Left Toe went from -0.10 to 0.15 (big change) Front Right Toe went from 0.10 to 0.15 Rear Left Camber is unadjustable at -0.07 Rear Right Camber is unadjustable at -1.4 (must be that curb that launched over) Rear Left toe was unchanged at 0.20 Rear Right toe was unchanged at -0.05 Is there a better allignment option? Is there something else to consider? |
How many miles on new tires? I run 34lbs front 40lbs rear after going to 17" Rotas with just below euro height, factory tbars and oversized sways.
Scott |
Did a Porsche shop do your alignment, or at least someone who's intimately familiar with old 911's?
Also, food for thought...every time I've replaced the rears only, my car has become nervous. I talked to Tyson Schmidt about it (a well known Porsche guru who used to frequent this board) and he mentioned that pairing old tires with new will almost always produce a nervous car because the rubber compounds and traction characteristics don't really match anymore (aged vs. new), sidewall flex changes, etc. He said that he always bites the bullet and replaces all four when his rears wear out. I do the same now and the difference is like night and day. |
Mixing new tires with old will do this. The new pair in the rear need to scrub in and heat cycle before the sidewall stiffness and treadblock squirm begin to match the fronts.
So right now the rear is steering the front, and will feel like the tail is wagging the dog until the rear tires stabilize. It's one of the downsides to rear engined cars. They are very tire-sensitive. |
That's great advice from everyone. Thanks. I will get a new front set next week based on that information. The rear tires have just several hundred miles on them (one week of daily driving) so they should be well matched when new fronts are added.
Do the allignment specs look right? And no - it was a tire shop that works on all kinds of cars and doesn't specialize in Porsches. I am tempted to take it to a Porsche experienced shop to set up all four corners with a competitive ride height and a competitive allignment set-up, but I was waiting to add some new bushings and maybe some stiffer torsion bars first. |
Due to the adjustability of our cars, corner balance can contribute to either ill or excellent handling. Consider checking/adjusting when your tire issues are resolved.
Sherwood |
Rear camber is NOT "unadjustable". It is easily adjusted. Camber of -1.4deg one side and -0.1 deg other side is not desirable. Rear toe-out is also not good for stability - should be slight (15') toe-in.
+1 on replacing all 4 tires at a time. I recall reading in a UpFixin' article (referring to early non-staggered tire cars) that Porsche required new tires to go on the front if only 2 tires are replaced. |
I agree, take it back to the alignment shop and show them how to adjust the rear camber before you buy new tires.
The self-alignment book used to be available on the dorkiphus site, start there. |
Toe-in also helps keep the car directionally stable. Toe-out makes for quick turn-in but can be "twitchy" on the freeway.
Before you take it back to Joe's Tire, consider either aligning it yourself or taking the car to a shop that knows something about 911's. I would not let some random shop put my car on a hoist, let alone start adjusting the rear trailing arm. It's not that difficult to do, but there is opportunity for a clueless hurried greasemonkey to screw things up. YMMV
I like all the caster you can get, 6.5* is great race cars can use close to zero toe, eevn some toe out but this leads to a darty car, spec is 0 pressed but a little toe in will quiet the car down a lot. 30' to 1* neg cambver is good for a street car rear a little more camber than in front 1* to 1* 30' is a good street setting toe as in the front |
OK. I'm thinking now that I need to get the car to a shop who can set up a Porsche properly - especially the rear camber. I'll start there and then add front tires. Thanks everyone for your insight. What a great resource.
have you put 200 miles on the new tires??
About 300 probably. Why?
The tires should be scrubbed-in after 300 miles. I think the twitchy handling is from the alignment rather than the tires.
Ronin,
What years 911 does "pressing" apply to? I just tried to have an alignment done and the shop did nothing of the sorts. Mines an '88. Where did this snippet of info come from please? (sorry to interrupt) Thanks |
I can only infer up to 1989 front factory specs when pressed there is a normal tendency for fronts to toe out aka: adding some toe in compensates for not pressing |
Please keep your threads together :)
http://forums.pelicanparts.com/porsche-911-technical-forum/484581-allignment-question.html?posted=1#post4771554 |
I think you guys are missing the fact that the rear alignment settings did not change before and after. They were not adjusted.
The only significant change was to front toe, and that was a small amount. It also went towards more toe-in, which would numb down the steering if anything. I also disagree that 300 miles is necessarily enough to break the tires in. It depends on how it was driven. You need to put some lateral scrubbing on the tires, and even more importantly, get them up to the right temp. Some canyon carving, an autocross, something like that will do the trick. |
Regarding tire scrubbing - I am now noticing that the problem is working itself out as I put more miles on the back tires. I will still seek an allignment from a Porsche friendly shop to fix the rear camber issue, and may request more toe-in front and back, but that is the call of the guy with the rack/street experience. BTW - The Toyo Proxis 4 tires are not expensive and I've found them to be great street tires, so I may as well get two front tires and save the others as emergency spares.
I'll add that scrubing the tires in only seems to help a little. When I had old fronts and newer rears, the nervousness never really went away. It got a little better, but that was about it. Not until I bought a set of four brand new tires did the car feel normal again.
You live in Ramona. You are not far from one of the best 911 suspension guys in existence, Jae Lee @ Mirage Intl in Mira Mesa. He's who you need to see.
| All times are GMT -8. The time now is 08:08 AM. |
