Leg room dilemma
I have an '86 Carrera, stock. My girlfriend wants to drive it but she can't touch the clutch pedal to the floor--even with the seat all the way forward. She isn't overly short either, but I guess her legs are short.
The dilemma: How can this problem be rectified? Is cutting the seat rails out and modifying their position the only way? Putting extensions on the pedals doesn't seem right...
Any input would be much appreciated!
Old 07-07-2009, 10:30 PM
Banned
Welcome.
Clearly a taller girlfriend is the answer.
Otherwise, race tape a block of wood onto the pedal.
Before you do anything expensive, permanent or elaborate- my SO is quite an accomplished club level track driver and she really wanted drive my (then) 86 Carrera. Till she actually did drive the 86 Carrera, and that solved the problem.
Fit a small Momo wheel and make sure the car is carrying a relatively aggressive alignment just to make sure and I doubt you will have this probem for long.
Edit: Also- You need to post pictures of the girlfriends legs. Its the olny way a real assesment of the problem can be offered.
Old 07-07-2009, 11:48 PM
docrodg's Avatar
Another solution is pillows behind her lower back to get her hips further forward.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-08-2009, 04:29 AM
carson911s's Avatar
'77 911S (3.2 SS)
'81 928 (gone)
Old 07-08-2009, 04:41 AM
safe's Avatar
Creative are we today...
I would try some form of lower back support as suggested. That has worked for short legged friends of mine.
ps. I agree about the pictures, it would be the only way that we could adequately help you/her.
Magnus
Old 07-08-2009, 05:17 AM
Thanks for the current input guys! All jokes aside, it's really something that needs a proper solution. Using padding behind the back might work, but I'm wondering if that'll change seat comfort.
Has anybody heard of anything else?
Thanks again!!
John
Old 07-08-2009, 06:16 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
How about one of those ortho-type back supports that you see in drug stores?
They invite you to sit in the chair to see how comfortable they are.
It would provide the forward position required and show the lady you are trying to make her driving experience better at the same time.
Bob
Bob Hutson
Old 07-08-2009, 07:07 AM
Detached Member
Hugh R's Avatar
It's a rule here that you have to post pics of the car and the SO if you want meaningful answers.
Hugh
Old 07-08-2009, 07:47 AM
The problem with moving the seat forward is she will be real close to the steering wheel and the shifter may be awkward to reach. My wife is short and peddle extenders fixed the problem so that she can fully engage the clutch and still have a comfortable reach to the controls. She did the pillow thing years ago but it's not the best solution. I'm over six foot so the biggest issue now is when I drive her cars!!@#!
Old 07-08-2009, 08:10 AM
docrodg's Avatar
I have the same problem! 6'1 and when wife drives a car and I get in I hit the dash with knees, if I can get in at all...
1968 911S "Leona"
Old 07-08-2009, 08:18 AM
safe's Avatar
Thanks again!!
John
Its pretty easy to remove a seat.
Do that and see if you could move the seat forward on the rail, that must be easier than moving the mounting point on the car.
But doing this limits how far back you can move your seat for your comfort.
Magnus
Old 07-08-2009, 08:30 AM
Happiest when Tinkering
gsmith660's Avatar
They do make pedal extensions I dont recall where I saw them but they do make them for height challenged people so they can drive. I would try a google search and modify them to be Porsche savy.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 07-08-2009, 09:01 AM
Wyvern's Avatar
Mr "John - Knee"
Interesting forum name considering your dilemma ..
Some of the Ortho Pads are high tech.
Funny that you posted this, because this weekend while watching the endurance racers on TV my SO noticed that the changing of seat backs was a regular thing to do for drivers of different heights.
In my case I was very quick to state that could NOT be done in my P car ...
Brian
Old 07-08-2009, 09:36 AM
Banned
Originally Posted by Wyvern View Post
Mr "John - Knee"
Racing seats are usually bolted to the roll cage. There is usually some adjustability, but this is a pits job, not at driver changeover function. So seat inserts (baby seats) are often used.
OP- quite seriously- before you do anything too elaborate- suggest you find out whether she really does want to drive a heavy steer, heavy clutch, 915 equipped 3.2 (with "airconitioning"?) or whether it just sounds like a great idea.
Old 07-08-2009, 06:31 PM
If you do not need full full extention back, remove the seat and reset the rail further forward. You will have to drill some new holes. Should not be a bid deal.
If you seats are electric, unplug them before you unbolt and bolt them up.
Should work.
Old 07-08-2009, 08:24 PM
piscator's Avatar
Just another point of view
I have somewhat short legs and experienced this problem. I can't explain why, but it went away when I raised the seat 1 1/2" It enabled me to sit closer to the wheel and seems to provide better leverage on the clutch. I have a lot less trouble getting it to the floor.
Of course, if you've already got the seat as far forward as it will go, my solution may not help. But it's not a hard one to test, just put a pillow on the seat. I did a lot of trial and error testing with foam behind and under me, before deciding to fabricate risers for the seat tracks.
The seats do come out easily and I didn't find the modification difficult. If you cut two lengths of steel channel you can bolt them into the existing holes, but a few inches forward of where the regular seat tracks sit. When you bolt the existing seat tracks to the steel channel you'll have the same amount of seat travel, only a little farther forward. You'll need to find a 'happy medium' to accomodate both drivers.
It wasn't a difficult project, I did it in an afternoon. If you don't like it, just rip it out and put it back to normal. It doesn't alter the car at all.
Good luck!
piscator
Old 07-08-2009, 10:51 PM
Thanks so much for the input everyone! I'll give a couple of the suggestions a try this weekend, hopefully something will work.
In passing, I think it's too bad many think that Porsche is a "man's car", suggesting I try and dissuade her from driving it or not take the issue seriously. They are amazing machines that provide fun and exhiliration for both genders
That being said, she better not scratch it... haha
Old 07-09-2009, 07:39 AM
Banned
Did anyone say that? I dont recall that it was either stated or implied. If you are referring to what I suggested, it was about making sure she really wanted to drive it before you engineered some elaborate solution.
It not that an older 911 is a mans car, its a drivers car.
Old 07-09-2009, 02:06 PM
An older 911 is mostly an older man's car.
I have never had a woman approach me or check me out in my 85 Carrera. It is always men over 50.
However, any time my friends Wife and daughter went out in his, they would come back with all kinds of stories about being approached...
Old 07-09-2009, 03:29 PM
safe's Avatar
That is so sad but true...
Well, young children likes it to sometimes.
Magnus
Old 07-09-2009, 04:11 PM
