Sanden 508/SD5H14 will it fit?
Looking to replace an OEM NipponDenso in an 1986 930.
Can I use the 508 instead of the 507? It looks a bit longer..
Thanks!
1986 930 Turbo (Stock) 39k
Huntington Beach, CA
Old 07-09-2009, 05:14 PM
Dr J's Avatar
No, it won't be a drop-in replacement. The 507 has 73.3 mm distance between the mounting ears, whereas the 508 has 83.3 mm.
An alternative is if you find something like SD5H11 or SD7H13, which have the same spacing (unless you fit some kind of adapter.)
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 07-11-2009, 08:48 AM
