Tire size question for 85 factory widebody
I am currently running a 245 50 16 Kuhmo on the rear and they no longer seem to be available in this size . Is there a wider option? thanks Doug
Doug 97 C2S 993(last one) 95 993 cab- 85 911 M491 87 944 Turbo- 70 914-6 63 911 |
I was curious and checked tirerack and found 3 pages of selection for this size
http://www.tirerack.com/tires/TireSearchResults.jsp?skipOver=true&width=245%2F&ratio=50&diameter=16&x=11&y=10
Fat butt 911, 1987 |
3.4 Bigger is better
Check out http://www.tirerack.com/tires/TireSearchResults.jsp?width=245%2F&ratio=50&diameter=16&x=13&y=13 There are three pages of tires in 245/50's
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Shouldn't you be running a 245/45?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
hoho.. this is funny. In fact I just remember. I think Bryan is right. It should be 245/45/16 nad it limit to 1/2 amount of the choices.
Doug,
The Kumho XS comes in a 265/45-16 which might work and 25.4' in diameter as compared 245/50 at 25.6". They have a 225/50 for the front if that is wide enough for the front. $178/ea for the rears from Discount tire/shipped http://www.kumhousa.com/Tire.aspx?id=675dce77-813e-4027-b467-2bea0466bd5c&cat=24 And a tire size calculator http://www.miata.net/garage/tirecalc.html
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 07-12-2009 at 09:48 PM.. |
