-   -   Do I need longer stud??? (Adding spacers you pervert) (http://forums.pelicanparts.com/porsche-911-technical-forum/4850-do-i-need-longer-stud-adding-spacers-you-pervert.html)
Mike Feinstein 06-11-2001 11:40 AM
Adding 1/4" spacers to fill out the rear wheel wells juuuusssttt right. Can I use my stock studs? I notice that most spacers come with longer studs if they are needed. Just want to make sure that my wheels don't fall off!
Thanks,
Mike 94 C2 cab
john walker's workshop 06-11-2001 11:52 AM
well, obviously you would loose 1/4" of thread. the lugnuts are soft aluminum. with steel lugnuts from a vw bus or 356, you would be safer. ugly though.
phillocks 06-11-2001 12:01 PM
Absolutely no problem, I have been running 20mm spacers (25mm = 1 inch)on a turbo 3.3.
No problem atall.
