Can 18" wheels ever look good on an SC?
What do you guys think? There sure are a lot of tires to pick from.
I like to think so
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
I'd have to see pictures... but I'd err on the side of no.
Personally I think Fuchs (or replica Fuchs) are the best look for the SCs. The 17"s (Jeff Altons or Rotas) look quite nice and don't diminsh the classic look. 18"s with low-profile tires to me would start to scream "Pimp-my-Porsche," especially if chromed. Then again, I'm a sucker for the classic look. To each his own I guess.
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
Oh, and I'm only 27... not exactly an "old man" yet.
Yes, yes they can:
![]() This is supercarrera81's car tha tI picked from another thread. While the red highlights are questionable, IMO, the wheels look awesome. EDIT:: The whole car looks awsome!!!
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
They might look good, but how well will the HP of a 911 SC 3.0L going through 915 gear ratios be able to pedal those 25" to 26" diameter tires????
With all due respect; When your older you'll think of the car 1st.
1980 911 - Metzger 3.6L 2016 Cayman S |
Ted, you realise that the stock tire diameter for most of the 911's we love is around 25", right?
maybe you meant 25 inch wheels? I agree, forthe most part with others that Fuchs look best on the SC/Carrera year 911s. That is one of the reasons I went from Cups back to the Fuchs look on my SC.
Man that looks very nice.
any more pics of it? http://forums.pelicanparts.com/uploads14/81+sc+18+wheels1244498242.jpg
MELO 911 911 3.2 CARRERA '88 JEEP CHEROKEE KJ '04 |
Band.
Werd.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Don't see why not...........i love mines....
Dave J. TOO many cars/Toys to list....... ![]() I'm a sucker for any Porsche...especially long hoods...with big flares Last edited by Mia911; 06-08-2009 at 05:26 PM.. |
Band.
That is off the chain, dog. Werd x2.
Now in 993 land ...
Indeed, larger wheels generally run lower profile tires. In the end it often comes out to the same diameter. I.e. my 17 inch wheels with the Toyo RA-1 are larger diameter than my 18" wheels with the Toyo TR-1s.
George |
They may look fine, but other factors come into play. Such as rolling fender lips. Different offsets, which change the scrub radius. Which may mean the car won't handle correctly without extensive (read expensive) suspension &/or alignment adjustments. Also, car may seem slower if there is any weight increase. Xtra weight, especially in wheels & tires can have a noticable effect on acceleration. IMHO, can't just slap em on & expect everything to be the same or better. Could be considerably worse.
The best they'll ever look...
Amir '83 911SC |
Dixie Boost Hooligan
NO...IF and when the SC maintains an original appearance. When the SC is converted to 964, 993 appearance then many Porsche styled 18's have an acceptable appearance. Some wheels and other wings, spoilers et al; end up looking like an unfortunate Fast and the Furious...ricer abomination.
Go Speedracer, go!
Every car pictured above has had the impact bumpers removed. Once you remove all the black rubber and replace with painted bumpers (Ruf, 964, etc.), the larger wheels seem to fit better. Just my opinion.
1981 SC ROW Coupe |
Painting the chrome window trim black, how?
It's all a mess, pitted, scratched dull and nasty looking, how should I do it?
Paint it with a satin black paint. Wurth is good as well as 3M products.
The key is in the prep, obviously. You may want to look at just buying some black trim and replacing it. EDIT: I see you've posted a ton of things wrong with your new car. I'm sorry that you are having such trouble. Stick with the Pelican group and we'll help you get it in good shape and a joy to drive.
Driver
If you had asked me this question a couple years ago, I would have thought that 18s look way too blingy. Cartoonish, even.
But, now, after I've seen it so many times (go over on the 930 forum, as several guys have gone to 18" wheels), it doesn't look so bad, if done properly.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
