What does your lower hood latch look like?
For you longhood folks, here are two lower lid latches for the trunk. One has a provision for the cable end to fit into, the other doesn't. Which one does yours look like? Please include the model year of your car in your response. Thanks!
http://forums.pelicanparts.com/uploa...1247617088.jpg |
I've got one of each. My 69 912 has a latch like the one on the left with the cable cover receptacle, and my 73.5T has a latch like the one on the right. Both cars have a rigid steel tube that lead to the housing on the bulkhead that holds the latches and they seem to be the same diameters. I did not follow the tube to where the cable enters so I don't know if the 73 has a shorter cover that ends at the tube opening or if the cable cover extends all the way to the housing, like on the 69.
Thanks L.J. I thought maybe the one on the left was for a 912 or a SWB 911, but PET shows the same part number from '65-'73 on both 911/912. I'll use the one on the right since that's what is on your '73.5T.
| All times are GMT -8. The time now is 07:46 PM. |
