Quick valve adjusment question
After adjusting the valves do you coat the valve cover gaskets with a thin coat of oil when you are assembling them? I'm using graphite gaskets and this is a 2.4 MFI engine.
Thanks! |
Install them dry, graphite is a dry lubricant. I would recommend buying the silicone gaskets they are reusable and seal the best IMO.
68 911L |
grateful user
yes on the silicon gaskets, they are great, can be reused over and over.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Thanks much.
Next time around I'll get the silicon gaskets. |
One more question...(this is my first time)
Should I let the car sit overnight after completing the adjustment before driving it? I thought i read that somewhere...??? |
Do the adjustment stoned-cold....but not heard of sitting overnight before driving....
Interesting footnote.....But I don't see why? Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Never heard that one. I just adjusted my valves and immediately after putting everything back together took it for a ride.
Harry
1974 911 2.7L coupe with sunroof |
Almost Banned Once
The theory is it helps the rocker cover gaskets seal as they have a chance to "mould" to the covers before being heated for the first time. Apparently once the gaskets are heated for the first time they loose some of their compliance.
- Peter |
Formerly known as Syzygy
That kinda makes sense...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Interesting,...look to hear from the P-wrenches here on this one ...never even thought about this one...
..quite interesting. Best, Doyle
grateful user
just go back and retorqe the covers after its warmed up and cooled back down
I think it makes more sense to let the car sit over night (cool) before adjust. After adjusted, why need to cool it?
Fat butt 911, 1987 |
