Thumbs up Stainless Steel Header for 3.2
Hello,
OBX Stainless Steel Header for 911 carrera 3,2 is good quality and performance ?
or could you tell me the best Stainless Steel Header for 911 carrera 3,2 ?
thank you
Old 07-18-2009, 03:47 PM
The stock ones.
They do not crack, are in expensive to replace used if dammaged , and the deliver most of the power potental of a stock motor when the cat is deleted, a sport muffler installed, and 911chips.com chip is added.
993 HE's convered by M+K mufflers w there sport muffler.
SSI's, They, add a little bit of power in the lower mid range.
B&B's make good peak HP, are expensive, and often crack.
Or somthing like that.
The OBX dose not have heat. They can make great power with the right muffler and again, with a 911chips.com chip.
Old 07-18-2009, 04:51 PM
amschnellsten's Avatar
I have a B&B with the heat exchangers and B&B muffler. Makes great power and sounds like a really really loud Ferrari. The stainless exchangers rattle a bit.
Old 07-18-2009, 05:06 PM
