Car is hesitating slightly--any ideas on cause
My car seems to hesitate just slightly on hard accelleration. I don't think its the clutch slipping. Could this be a fuel pump or other type of issue? Not sure where to start here. Thanks
1980 911SC Targa 3.6L
Old 07-16-2009, 11:26 AM
porsher
aston@ultrasw.c's Avatar
Start with the basics: plugs, wires, fuel filter, distributor, fuel pressure etc....
Then you can get into more advanced stuff: vacuum leaks, O2 sensor, AFM, injector wiring, crank speed sensor, CHT sensor, DME etc...
A defective clutch tends to slip at max torque e.g. 3rd gear, up a hill, 2000 rpm, wide open throttle. Rpms increase, speed does not.
Old 07-16-2009, 12:02 PM
dshepp806's Avatar
Start the elimination process...as this could be many things (as indicated by Aston)
Best
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-16-2009, 03:02 PM
