-   -   my rear trailing arms are different. (http://forums.pelicanparts.com/porsche-911-technical-forum/48582-my-rear-trailing-arms-different.html)
kumma 02-14-2001 11:05 AM
I just took off the rear trailing arms they are different from each other. One side has a bolt with a round head on it and the other has nothing on it. It looks like it might be a sway bar attachment point. Both of them are steel. I plan on adding weltmeister sway bars, will the differences be a problem or do i stll have to buy the rear adapter kit to install the rear bar.
Early_S_Man 02-14-2001 03:28 PM
Well, I presume your car is pre-'74, right,? And, didn't have a rear factory anti-roll bar from the factory, right? So, it appears that someone along the line replaced the trailing arm that has the attachment stud for the anti-roll bar. You will indeed have to install the counterpart on the other side, as well as the body mounts for the bar!
Warren Hall
1973 911S Targa
Evans, Marv 02-14-2001 04:14 PM
A couple of questions on anti-sway bars. I will be installing one on the back on my '72E. It doesn't have the body-mounted brackets. I have a couple of aluminum swing arms. One is a '78(?) or later with the bolted drop link. The other has the ball mount. I think I'd prefer to have the bolted drop link. Can I remove the ball mount & buy a bolt-on drop link & install it? My other question is - I bought the anti-sway bar kit that bolts onto the torque tube. It has the big U-bolts that go around the tube & the brackets are attached to them. Is this a good way of mounting the sway bar? Has anybody out there had experience with one of these???
turbo6bar 02-14-2001 04:24 PM
Stoddard sells the ball-end inserts, but I am not sure if you can remove those inserts from the arm. They don't sell the threaded inserts, like those found on later arms.
What I did was use a portable electric bandsaw to cut off the ball. I then used various drill bits in progressive fashion to make a hole in the rest of the insert. I then tapped the hole with a metric 10mm tap. I believe it was a 10x1.5mm tap, but I am not 100% sure. Make sure you use a bottoming tap. I can get you pictures, if you would like.
The job is best performed when the trailing arm is removed from the body. I did this work during a rear bushing job.
Jay
