RSW RSW is offline
RSW's Avatar
Unhappy Heater Flap/Box mounting studs.
Ok so I've snapped all the mounting studs at the passenger side heater flap box. The 101 book says these are welded in at the factory and they are a pain if they snap.
Has anyone got any ideas of how to mount the new flap/box now?
Surely I aren't the first to have this problem.
Many Thanks
RIchard
1988 911 Carrera 3.2
Old 11-21-2002, 08:45 AM
s_wilwerding's Avatar
I just read a thread about this the other day. I believe somebody mounted the new flapper box and had a muffler shop spot weld them to the broken studs. As long as you don't anticipate changing them out again any time soon (and if you buy new ones you shouldn't have to), this should work for you.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 11-21-2002, 09:28 AM
cary's Avatar
Is the engine in or out ???
One of mine broke off. When I was cleaning them up and changing heater cables. I welded in a new stud with my wire feed.
But be REAL careful, all that undercoating wants to ignite. Get it cleaned up real good before you go welding .
Short term fix, maybe a Stainless Steel screw to hold it in place.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 11-21-2002, 09:34 AM
if just one stud breaks, just leave it. all three is definitely a problem, as there's no room to work up there. a couple of spot welds would be easiest. even trying to drill a couple of holes for screws is a joke. marinate those nuts overnight if they look rusty, and if they still won't turn, do it again.
206 637 4071
Old 11-21-2002, 01:01 PM
47silver's Avatar
heater flaps
are you mounting the a new one from pelican? my son and i did this about a month ago, all of the studs snapped. and i said a few choice words about the design. i noticed that there was a little thread left on the stud so i tried the pelican flapper on with out the gasket and it left a tad of thread.
The flapper is formed with a bulge that keeps the hole away from the frame. i put the flapper in a vise and compressed it to make the edges flat, so i would have more thread to work with. i was able to get all 3 nuts on and i tightened them down and then removed one at a time we were able to get a washer on 2 of them. i also put on the stuff so that you can take them off later. it is at the parts store too.
hope this works for you. if there is even 3/8 of an inch of stud you can get it to work i think.
gary
screwed on.
1975 911S Targa
Silver Anniversary Edition
Old 11-21-2002, 01:19 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
You could grind off the Nub till flush, drill a .343 dia. hole and install a Rivstud
These actually work pretty good.. it's not a temporary fix at all.
Jorge (Targa Dude)
Old 11-21-2002, 01:50 PM
Senior Member
Doug Zielke's Avatar
Great call, T Dude!
I have used them (Rivstuds and Rivnuts) and they are a teriffic product for anything that doesn't require *huge* tensile or sheer strength. Perfect for the flapper box re & re.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-21-2002, 02:45 PM
Friend of Warren
How do you get those to hold? Is it like a regular rivet that you use a rivet gun with or do you have to hammer on the back side?
Kurt V
Old 11-21-2002, 02:53 PM
Information Junky
island911's Avatar
they *are* a teriffic product. . .even for applications that do require *huge* tensile or sheer strength. You just need the right size, and load them in the correct direction.
Old 11-21-2002, 02:54 PM
Senior Member
Kurt,
You draw them up with a special little tool. The inside part mushrooms/collapses, and it grips very tightly.
island....whatever you say; just don't use them to replace Dilivar head studs.
Old 11-21-2002, 02:57 PM
Information Junky
island911's Avatar
Originally posted by Doug Zielke
. . . just don't use them to replace Dilivar head studs.
heh heh. okay, but I have used them to mount a huge panel antenna. ~25 sqr feet with a design load from a 120 mph buffeting wind. You should have seen that thing dance, mounted to one of Boeings shaker (induced vibration) tables. It would give you a lot of respect for what these things will take.
As far as special installation tools, I'm guessing your thinking of PEM type of press-in inserts. These riv-nuts install by running a screw through them, essentially. (or a nut for the stud type)
EDIT:while there is a tool to speed installation, it's not needed for the DIY'er
Old 11-21-2002, 03:08 PM
Information Junky
island911's Avatar
For those interested, my perference on this type of fastener is AVK. The link is their home page. there are lot's of distributors of their product.
Old 11-21-2002, 03:28 PM
Todd Simpson's Avatar
For anyone who hasn't done this nasty job yet, soaking the studs with liquid wrench a day in advance then hitting them with a torch really helps. I got 5 out of 6 off cleanly this way, using only a little torque then working them back and forth helps too.
Where the 1 stud broke, I drilled a small hole and put a self tapping screw.
Old 11-21-2002, 04:32 PM
RSW RSW is offline
RSW's Avatar
Thanks for all you advice - I like the sound of those rivits/studs although I've never seen them in th eUK - I'm sure some one will stock them.
I managed to get one nut on as there was just enough thread - I'll try flattering the rim and see if I have any more luck. Do I need that gasket on there?
Also When I spin my fan controll (it's the electronic sort) to position 1 from 0 it seems to open the flaps all the way? If i then go to position 2,3,4 etc no further movement occures?
I have the engine and box out of the car (STILL!) but I don't think this would make any difference.
ANy further thoughts - or does it just need adjusting at the switch end?
Thanks Again
RIchard
Old 11-22-2002, 12:34 AM
flapper box mounting studs
Thanks for all the advice. Gonna attempt this soon. Both of my boxes are disintegrated. Is it recommended to change the cable as well? Does the gasket come with the replacement boxes?
Old 07-20-2009, 07:46 PM
heater flappers
I painted my engine bay and replaced the flappers. I believe I had to order the gaskets seperate from the flappers. Be carefull with the studs, I snapped several and had to drill them out for threaded inserts. Some pictures of the process...
Old 07-21-2009, 09:41 AM
burgermeister's Avatar
Seems one could cut out a gasket-shaped plate of sheetmetal to fit (don't forget big hole in middle), weld new studs onto the plate (off car, using the new flapper box as a template), punch / drill a few holes in the plate, and puddle weld (aka Mig "spot weld") said plate over the opening. Voila, new studs.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-21-2009, 02:19 PM
robmog's Avatar
how i did it
a slightly different way.
1) broken stud
2) cut off flush
3) 5 mm drill thru center and m6 metric tap
4) cut head off m6 bolt
5) screw in bolt
6) braze bolt to frame
good as new and looks correct
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 07-21-2009, 02:53 PM
