1977 911S 3.2L Conversion
I have a 77 911S, which I am converting to a 3.2L with Weber carbs, and SSI's. Will I have to change the distributor, and will I need to keep the motronic system with the 3.2L? I don't want to cut a hole in the car to install the wiring harnass if it is not needed. In the future, I plan to upgrade the engine with higher compression pistons and a cam. Does anyone know the proper way to do this conversion without making it too difficult? Any help would be appreciated.
Thanks Ozzie osyve@stic.net |
You can use the distributor from your 2.7 in the 3.2. I would use the dizzy to trigger a MSD 6al. About as simple as it gets. The distributor should be recurved.
This probably should be posted in the technical section though
No left turn un stoned |
Thanks for the help! I couldn't find a way to post this msg there, so I put it here. This site is "extremely helpful! Thanks again!
By the way, what is a "dizzy" used to trigger this setup? Can I use the MSD that came with the car?
