Squeal like a pig boy!..a fan revalation
I have in the past thrown out some enquries regarding my recalcitrant auto-heat issues. Now I think have the solution.
Prior to the heat deciding to quit, I now remember that my engine compartment blower fan was squealing more than Ned Beatty in "Deliverance".
With that said, I now know I need to repair or replace the fan.
Question..... could I have damaged anything else by letting the fan break?
Thanks so much.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-14-2011, 08:12 AM
Fleabit peanut monkey
Bob Kontak's Avatar
This is one that needs more explanation. Is a pic possible? Are chunks missing?
If chunks of the fan got sucked into the top of the engine case there are no moving parts in there and nothing too fragile.. If it got sucked all the way back on the passenger side there could be some air obstruction for the engine mounted oil cooler.
Old 02-14-2011, 08:30 AM
Bob, this is the heater fan, not the cooling fan.
Old 02-14-2011, 08:47 AM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
it's pretty easy to take it apart and overhaul it. My suspicion is that if you get another one it will be worn out just like the one you have. Just open it up, lube the bushings and make sure the brushes are not worn out.
Mark Petry
Bainbridge Island, WA
81 SC
Old 02-14-2011, 08:51 AM
RETIRED
Joe Bob's Avatar
The engine blower needs to be working for the foot well blowers to work and that's all she wrote.
The rebuild parts are available....cheaper than buying new. Lot's of stuff to disconnect, be careful of the heater tubes. They can be brittle and will rip and tear due to engine heat, especially the paper/tin ones.
2012 ML350 3.0 Turbo Diesel
Old 02-14-2011, 09:03 AM
Bob Kontak's Avatar
Doh
Old 02-14-2011, 09:09 AM
ghamilton's Avatar
I assume the fuse blew, if not pull it that's a lot of draw and potential fire hazard if it is still getting current and not turning..
Actually just pulled my fan this weekend while I was replacing the hoses. Pulls apart easily and took 20 minutes to clean it, and apply some white litium grease to the bushings. Mine was turning but a little squeely, brushes were just 1/2 worn, so sticking with them for now.
Now quite and smooth as silk!
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 02-14-2011, 09:10 AM
pelican lists the fan motor, less fan and housing for a pretty good price compared to the whole $$$$ unit.
206 637 4071
Old 02-14-2011, 09:30 AM
Thanks so much.
Doesn't sound like such a bad fix.
Or look for the Grainger-motor fix desrcribed within these pages too.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-14-2011, 09:53 AM
I took John Walker's advice and ordered the new fan from our illustrious host. As long as the plug modification goes well, it looks to be the most direct route.
Thanks, John!!
Old 02-25-2011, 08:32 AM
By the time the heater blower fan wears out and quits, the brushes, bushings, armature, etc are all pretty much shot. I can see bolting in a new electric blower motor, but I can't see trying to rebuild the old one.
Old 02-25-2011, 11:34 AM
RETIRED
Joe Bob's Avatar
Some people will DIY because they can.....the parts are available as are complete motors. I went with marine bilge blowers. Higher CFM and WAY cheaper.
Old 02-25-2011, 11:39 AM
ghamilton's Avatar
I guess I got to mine before it self destructed. Is the quality of the new ones as good? I tend to doubt it as with many replacement parts.
G. Hamilton
"Bumerang"
'70 TR6
N of Boston
Old 02-25-2011, 11:42 AM
Give me a week until I get the new one in and I will be able to provide an unbiased report. On most things, I like to take the DIY approach, but for a bit over $100 for a new motor it seems like I am getting peace of mind for not a lot of cash.
Old 02-25-2011, 11:58 AM
