Killer Tip - motor mounts
Score one for Charles K who posted a tip on motor mounts. I did these tonight and it was an absolute breeze.
Here is the tip: 1) Super glue the lock washers to the nuts. 2) Put duct tape sticky side out on your middle fingertip. 3) Place the nut/washer on the tape. 4) Tighten the bolt with the nut in place on your finger. Let me tell you there is genius in this!!! I have used masking tape to hold the nut & washer together in the past. This is 100% better than that. In my clumsiness, I did invent a tool that has considerable merit. My daughter seems to have run off with the magnetic picker upper with the long flexible handle. I dropped a nut/washer and needed an easy way to pick it up. I found a rare earth super magnet and taped it to a small dowel. PERFECT. Even though the magnet is less than 1/2 inch in diameter, it had the power to pick up on of the large washers that goes under the motor mount. Just thought I would share. Larry |
You must be one of THOSE guys who has an OLD car whose motor mounts actually need NUTS :) :)
Never realized it was a problem...
| All times are GMT -8. The time now is 04:55 PM. |
