hank911
Guest
Posts: n/a
torsion plate inclination %??
i'm putting 27mm rear bars and would like some advise on lowering set up????bently specs the 83sc euro @ 34% w/stock 24.1mmm bars.like i said i'm going to 27mm's,same inclination angle or ???????? as always,thanks folks, hank911....
Old 02-15-2001, 04:25 PM
Early_S_Man
Guest
Posts: n/a
Hank,
Quite a bit less inclination will be needed, perhaps 30 degrees, or less. If you get it too low, you can adjust the ride height with the adjustable two piece spring plates.
Warren Hall
1973 911S Targa
Old 02-15-2001, 04:46 PM
hank911
Guest
Posts: n/a
Thanks Warren,on this subject,do you know of any references that might detail different set ups.Everything I've seen seems to say a little trial n error is to be expected,just that I'd love to eliminate as much "error" as possible! Thanks again, PHP...
Old 02-16-2001, 04:53 AM
