-   -   just replacing my AC temp switch where does this tube.. (http://forums.pelicanparts.com/porsche-911-technical-forum/486272-just-replacing-my-ac-temp-switch-where-does-tube.html)
ertech 07-19-2009 03:27 PM
in the process of replacing my AC temp switch and i found this brass tube in the evap housing . is this brass tube part of the old switch or should I put my new swich wire through it ?
Thankshttp://forums.pelicanparts.com/uploa...1248042450.jpg
DonMo 07-19-2009 03:31 PM
It fits in our condenser coils and the capillary tube from the temp sensor in it.
rsscotty 07-19-2009 03:34 PM
Just a small correction ... it goes in the evaporator.
tomphot 07-19-2009 03:39 PM
You should have a white wire that inserts into the brass tube through a hole in the top of the evap box. coat the wire with grease before you insert it.
