Fanatical User
1974 & 1975 Carrera's HELP
I run a 1975 Carrera (whale tail) and a friend a 1974 Carrera (duck tail). Both decklids are factory and both deck lid grills are plastic. I thought they were BOTH supposed to be metal, black anodized. Can anyone shed light as to the authenticity of these grills? When did they go to plastic?
Old 07-20-2009, 03:21 PM
working in the garage
JHinOH's Avatar
I can't answer your question directly, but I can add my '74 duck tail has the black metal grill.
Old 07-20-2009, 04:10 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
i have a 75 carrera and bought it from the original owner and it has the plastic grill. i have also seen two other 75s and they both have a plastic grill. so maybe they could have had either or?
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 07-20-2009, 04:15 PM
Fanatical User
JHinOH - is yours painted black or anodized black?
carrera turbo - could this elude to the fact maybe 1975 was the first years of plastic?
Old 07-20-2009, 05:56 PM
JHinOH's Avatar
It appears anodized, and it's actually aluminum. Definitely not plastic though, it uses 8mm nuts to attach to the fiberglass tail underneath.
Old 07-20-2009, 06:07 PM
UNDER CONSTRUCTION!
yes i would say this is the first year for plastic as i thought about it and remember seeing a 74 with the alloy or metal gril but it was not black so maybe an add on? but im pretty sure all 75s came with the plastic.
cheers ed
Old 07-20-2009, 06:25 PM
Fanatical User
JHinOH - did you buy your 74 new or did you buy it from the original owner? Trying to determine what a 1974 Carrera SHOULD have.
Old 07-20-2009, 06:26 PM
JHinOH's Avatar
Nope, neither sorry. I did have someone familiar with restoration on these indicate the tail appeared factory. I've owned it 10 years and got it in very "original" shape (read lots of money and work slowly refreshing it) and it had a lot of correct 74 Carrera stuff on it like thicker 3 spoke steering wheel, s calipers, correct engine/trans, original seats, original Fuchs, etc. so I would take a guess and say that is the correct grill for the '74 as everything else on the car was stock.
Old 07-20-2009, 06:38 PM
Gasoline User
1974carrera's Avatar
All the 1974 911s, including the Carrera, used the metal grill. I'm not sure when the grills were changed to plastic, but it was definitely after the 1974 model year.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 07-20-2009, 07:22 PM
group911@aol.co's Avatar
I bought a 75 Carrera #164 in 1976 and it had a plastic grill.
Thanks,
Bob
group911@aol.com
Old 07-20-2009, 07:50 PM
aro911t's Avatar
Grill
Definitely anodized aluminum on my 74 duck .
R-Gruppe # 558 s-registry # 1721 pca-gcr
1970 911T(R-gruppe project ) (Metallic Green)
1973 911T Targa (Gemini Blue)
1974 911 Carrera (#329 Lime Green)
67s restoration in progress
Old 07-20-2009, 09:24 PM
