Does anyone know how to seal the fresh air blower housing so it doesn't leak water into my trunk and down into the smuggler's box?
When water is poured in here, water comes out the drain under the car and also, comes out here..
1995 993 Carrera, Guards Red Coupe (current) 1987 911 Carrera, Marine Blau Metallic (06-08) Gone but... 1965 Yellow Mustang Convertible (65-05) __________________________________________ It is always a good idea to keep the pointy end going forward as much as possible. Last edited by jhubs; 03-12-2007 at 08:35 PM.. |
Is there a sealing ring that goes in between the "clam shell" cover over the motor?
Jerry
1995 993 Carrera, Guards Red Coupe (current) 1987 911 Carrera, Marine Blau Metallic (06-08) Gone but... 1965 Yellow Mustang Convertible (65-05) __________________________________________ It is always a good idea to keep the pointy end going forward as much as possible. |
Back in New England!
Jerry,
I know there is a rubber gasket on the intake lip for the fresh air blower housing that mates into the metal frame. The housing then compresses gasket into the oriface when you tighten each of the screws (one on each side of the fresh air intake). They are the screws behind the mesh. Hopefully this is what you were asking about. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
There is a baffle inside the housing that diverts water around the fan to the bottom of the housing where there is a drain (item #2). Perhaps your drain is partially clogged. I believe the drain hose passes thru the smugglers box to the bottom of the car (see pic). You might be able to clear it from there or from under the car. I think you have to remove the belly pan to do it from under the car.
![]() Good luck Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 03-13-2007 at 12:47 PM.. |
I fixed all the leaks..
Here is what i did on each problem. On the fresh air intake grill, I put a "new" black electric tape gasket all around and on the ends. Then I found that the two end screw holes in on the car body leaked water into the trunk. I placed a small donut rubber washer on each end screw. I found out that there is a flimsy gasket between the clamshell motor cover and the motor unit. I loosened up the bolts and pried the two halves apart a little and filled the gap with black silicone. I tightened the bolt back down and added another screw to pull the two halves together a little tighter. Now no leaks. ![]() Both upper corners of the hood leaked water into the trunk and the one on the passenger side allowed water to leak into the floor of the passenger side near the floorboard. I put black silicone in the crack/hole between the rubber trim and the car body. Now no leaks. Both lower corners leaked water into the rear deck area and rear seats. I dried out the window trim and carefully filled with black Silicone. I saved having to have the rear window reset...for now.
anyone know the part # for the gasket at the "clam shell"
got the same problem . Thanks |
