Steve F
Guest
Posts: n/a
Wieght question please
Can anyone tell me the wieght difference between 912 engine and a 2.0 911 engine. Thanks in advance!
Old 02-16-2001, 09:44 AM
Evans, Marv
Guest
Posts: n/a
Don't know exactly, but in the new Panorama, there's an article about a guy who put a '73T in a 356. The article commented the flat 6 was about 100 lb. heavier than the 4 banger.
Marv Evans
'72 911E
Old 02-16-2001, 01:07 PM
Early_S_Man
Guest
Posts: n/a
Steve,
Is the 2.0 an early aluminum crankcase, or a later magnesium one? The early ones are at least 22 lbs heavier!
Warren Hall
1973 911S Targa
Old 02-16-2001, 03:18 PM
Steve F
Guest
Posts: n/a
Warren,
Sorry, I don't know yet. It is somewhere up in Canada as a speculitive(sp) purchase.I thought maybe because the displacment was close to the original engine,not counting the extra cams ,cylinders and so forth, that it wouldn't play overkill on my 912 suspension.For what its worth, the engine #
is 6190745.Thanks for your input.
Old 02-16-2001, 03:48 PM
Early_S_Man
Guest
Posts: n/a
Steve,
OK, that is a magnesium-cased '69 'T' engine and my spec book says it weighs 176 kg or 388 lbs, so that would be just about 100 lbs heavier than the 912 engine, that is almost identical in weight to a VW Type 1 engine at around 280 lbs.
Warren Hall
1973 911S Targa
Old 02-16-2001, 04:06 PM
